interfasys
OK. Thanks for looking that up. I only checked the power_user skin and it wasn't there...
Make sure you forward your fix to the DA staff
Nov 17, 2003 - user/ssl.html - in setRequest - change document.all to document.info
This is nether bug nor translation issue. That code is for result:interfasys said:I still have a problem with that SSL page.
Right before the main table on the right, I saw a :
<b></b><br />
<br />
in the code.
Is this a skin bug or a translation issue?
Variable |RESULT| will be shown only when you submit that form and until then it is empty.<b>|RESULT|</b><br />
<br />
Je viens de Shawinigan qui est à environ 30 minutes de Trois-RivièresUltimeWWW said:Do you come from Europe guys?
Je viens de Montréal
Can you update the screen shots to show these?CyberAlien said:Updated to 1.01
Changes:
- fixed few bugs
- added versions to language packs (version can be seen in skins page)
- added current domain text to user panel
- removed links to panels in footer and instead put it in navigation
- added navigation to files that didn't have it
CyberAlien said:This is nether bug nor translation issue. That code is for result:
