interfasys
Cool!
could you share what you did on your RH9 box for the other RH9 users?torp said:Working well with RH9 rpm, Exim 4.60, SA, ClamAV and RBS
I'm ready to speed up Imap by adding Dovecot now, right?
RoRoo said:could you share what you did on your RH9 box for the other RH9 users?
3) Update to latest exim.confwget http://files.directadmin.com/services/9/da_exim-4.60-1.i386.rpm
rpm -Uvh da_exim-4.60-1.i386.rpm
4) Edit new exim.conf to include in line 1:mv /etc/exim.conf /etc/exim.conf.bak
mv /etc/exim.rpmnew /etc/exim.conf
5) Added ACL to exim.conf to deny messages with virus:av_scanner = clamd:127.0.0.1 3310
6) Uncomment spamassassin configs in the next section of exim.conf, to enable SAcheck_message:
# Reject virus infected messages.
deny message = This message contains a virus or other harmful content ($malware_name)
malware = *
warn message = X-Antivirus-Scanner: Scanned with Exiscan. You should still use an antivirus.
accept
8) Restarted exim:touch /etc/virtual/bad_sender_hosts
chown mail:mail /etc/virtual/bad_sender_hosts
chmod 644 /etc/virtual/bad_sender_hosts
touch /etc/virtual/blacklist_domains
chown mail:mail /etc/virtual/blacklist_domainschmod 644 /etc/virtual/blacklist_domains
touch /etc/virtual/blacklist_senders
chown mail:mail /etc/virtual/blacklist_senders
chmod 644 /etc/virtual/blacklist_senders
touch /etc/virtual/whitelist_domains
chown mail:mail /etc/virtual/whitelist_domains
chmod 644 /etc/virtual/whitelist_domains
touch /etc/virtual/whitelist_hosts
chown mail:mail /etc/virtual/whitelist_hosts
chmod 644 /etc/virtual/whitelist_hosts
touch /etc/virtual/whitelist_senders
chown mail:mail /etc/virtual/whitelist_senders
chmod 644 /etc/virtual/whitelist_senders
/etc/init.d/exim restart
hail said:Hi
after upgrade to exim 4.6 get these error ,
service exim restart
Shutting down exim:
Starting exim: /usr/sbin/exim: error while loading shared libraries: libdb-4.2.so: cannot open shared object file: No such file or directory
any help plz
I'm not sure what you mean. I removed the README and made it a separate file, available here.Dennis said:The readme about spamblocker is removed from this threat because Jeff is working on it I guess.....
There are several whitelist files:but how can I put some server ip's in the whitelist.
getUP said:Code:wget [url]http://files.directadmin.com/services/da_exim-4.60-1.src.rpm[/url] rpm -ivh da_exim-4.60-1.src.rpm cd /usr/src/redhat/SPECS rpmbuild -bb exim.spec cd /usr/src/redhat/RPMS/i386 rpm -Uvh --force --nodeps da_exim-4.60-1.i386.rpm
This should do it.
