twhiting9275
Here's a very simple script based on what was just given:
A couple of things wrong, which have yet to be corrected in any version of this:
Firstly, when using "domainlist", you get a bunch (and I do mean a bunch) of Malformed UTF errors. There's a good 1-200 of those errors so I'm not going to paste those.
Secondly, "all" does not work, at least for RHEL3. I couldn't get it to work under 9 either, so its probably NOT the OS. Error follows:
It's generating the html stuff, but it's not generating them properly, obviously.
USER="insertuser"
EDITOR="pico"
cd /home/$USER/public_html
mkdir awstats
cd awstats
wget [url]http://www.febox.com/DA-awstats.tar.gz[/url]
tar xzvf DA-awstats.tar.gz
cd ..
chown -R $USER.$USER awstats
cd awstats
$EDITOR common.conf
$EDITOR config.php
$EDITOR domains.txt
su - $USER
cd public_html/awstats
php domainlist.php
Warning: Syntax error line 5 in file './aws.wolfstream.net.conf'. Config line is ignored.
Error: LogFormat parameter is not defined in config/domain file
Setup ('./aws.wolfstream.net.conf' file, web server or permissions) may be wrong.
See AWStats documentation in 'docs' directory for informations on how to setup aws.
