ERRORS with EXIM AND CLAMAV
Hi I'am from Poland. My exim did not work. Today I update exim to 4.67 and now exim is down and cant start. Please help me with this
I have DA since few month. My name is Arek Kowalski. Please help me with this because my serwer must working.
[root@ah24 Soft]# /etc/init.d/exim restart
Shutting down exim: /etc/init.d/exim: line 40: kill: (16237) - Nie ma takiego procesu
Starting exim: /etc/init.d/exim: line 30: /usr/sbin/exim: Nie ma takiego pliku ani katalogu
......i will try this:
"wget
http://files.directadmin.com/services/da_exim-4.67-1.src.rpm
rpmbuild --rebuild da_exim-4.67-1.src.rpm
rpm -Uvh /usr/src/redhat/RPMS/i386/da_exim-4.67-1.i386.rpm
/sbin/service exim restart"
and there is meny errors:
gcc exim_dbmbuild.c
In file included from exim.h:433,
from exim_dbmbuild.c:33:
dbstuff.h:103:16: db.h: Nie ma takiego pliku ani katalogu
dbstuff.h:529: error: syntax error before "DB"
dbstuff.h:529: warning: no semicolon at end of struct or union
dbstuff.h:531: error: syntax error before '}' token
dbstuff.h:531: warning: data definition has no type or storage class
In file included from exim.h:437,
dbfunctions.h:13: error: syntax error before '*' token
dbfunctions.h:14: error: syntax error before '*' token
dbfunctions.h:15: error: syntax error before '*' token
dbfunctions.h:15: error: syntax error before "open_db"
dbfunctions.h:15: warning: data definition has no type or storage class
dbfunctions.h:16: error: syntax error before '*' token
dbfunctions.h:17: error: syntax error before '*' token
dbfunctions.h:18: error: syntax error before '*' token
exim_dbmbuild.c: In function `main':
exim_dbmbuild.c:150: error: `DB' undeclared (first use in this function)
exim_dbmbuild.c:150: error: (Each undeclared identifier is reported only once
exim_dbmbuild.c:150: error: for each function it appears in.)
exim_dbmbuild.c:150: error: `d' undeclared (first use in this function)
exim_dbmbuild.c:151: error: `DBT' undeclared (first use in this function)
exim_dbmbuild.c:151: error: syntax error before "key"
exim_dbmbuild.c:213: error: `DB_HASH' undeclared (first use in this function)
exim_dbmbuild.c:295: error: `content' undeclared (first use in this function)
exim_dbmbuild.c:298: error: `key' undeclared (first use in this function)
exim_dbmbuild.c:298: error: `R_NOOVERWRITE' undeclared (first use in this function)
make[1]: *** [exim_dbmbuild.o] Błąd 1
make[1]: Leaving directory `/usr/src/redhat/BUILD/da_exim-4.67/build-Linux-i386'
make: *** [go] Błąd 2
błąd: Błędny status wyjścia z /var/tmp/rpm-tmp.2600 (%build)
with clamav also are errors, look:
[root@ah24 Soft]# /etc/init.d/clamd restart
/etc/init.d/clamd: line 32: Killall: command not found
cat: /var/run/clamd.pid: Nie ma takiego pliku ani katalogu
kill: usage: kill [-s sigspec | -n signum | -sigspec] [pid | job]... or kill -l [sigspec]
please help me solve this problem, please!
im very sory for two posts
