XBL
In a few weeks we will probably update to the latest version (0.6.0). I'll post my results and an updated how-to. Not now, since I'm kinda busy.getUP said:Any update on this with the latest versions?
Jochem
CREDITS Makefile.frag README.FastCGI cgi_main.c config9.m4 getopt.c libfcgi php.sym php_getopt.h
without make install# ./configure --with-apxs2 --with-curl --with-curl-dir=/usr/local/lib --with-gd --with-gd-dir=/usr/local/lib --with-gettext --with-jpeg-dir=/usr/local/lib --with-kerberos --with-mcrypt --with-mhash --with-mysql=/usr --with-pear --with-png-dir=/usr/local/lib --with-xml --with-zlib --with-zlib-dir=/usr/local/lib --with-zip --enable-bcmath --enable-calendar --enable-ftp --enable-magic-quotes --enable-sockets --enable-track-vars --enable-mbstring --enable-memory-limit --enable-fastcgi
# make
ServerRoot "/etc/httpd"
PidFile /var/run/httpd.pid
Timeout 300
KeepAlive Off
MaxKeepAliveRequests 100
KeepAliveTimeout 15
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule prefork.c>
StartServers 5
MinSpareServers 5
MaxSpareServers 50
MaxClients 50
MaxRequestsPerChild 100
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule worker.c>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
# perchild MPM
# NumServers: constant number of server processes
# StartThreads: initial number of worker threads in each server process
# MaxThreadsPerChild: maximum number of worker threads in each server process
# MaxRequestsPerChild: maximum number of connections per server process
<IfModule perchild.c>
NumServers 5
StartThreads 5
MinSpareThreads 5
MaxSpareThreads 10
MaxThreadsPerChild 20
</IfModule>
Listen 0.0.0.0:80
# Dynamic Shared Object (DSO) Support
LoadModule php4_module /usr/lib/apache/libphp4.so
LoadModule frontpage_module /usr/lib/apache/mod_frontpage.so
LoadModule perl_module /usr/lib/apache/mod_perl.so
#LoadModule security_module /usr/lib/apache/mod_security.so
User apache
Group apache
ServerAdmin admin@localhost
UseCanonicalName Off
DocumentRoot "/var/www/html"
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory "/var/www/html">
Options -Indexes FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
#this is setup, but via alternate means
UserDir disabled
AddHandler cgi-script .cgi .pl
<Directory /home/*>
AllowOverride All
Options MultiViews -Indexes FollowSymlinks IncludesNoExec +Includes
<Limit GET POST OPTIONS PROPFIND>
Order allow,deny
Allow from all
</Limit>
<LimitExcept GET POST OPTIONS PROPFIND>
Order deny,allow
Deny from all
</LimitExcept>
</Directory>
DirectoryIndex index.html index.html.var index.htm index.shtml index.php index.php4 index.php3 index.phtml index.cgi
AccessFileName .htaccess
<Files ~ "^\.ht">
Order allow,deny
Deny from all
</Files>
TypesConfig /etc/mime.types
DefaultType text/plain
<IfModule mod_mime_magic.c>
MIMEMagicFile conf/magic
</IfModule>
HostnameLookups Off
EnableMMAP on
EnableSendfile on
ErrorLog /var/log/httpd/error_log
LogLevel warn
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
LogFormat "%b" bytes
CustomLog /var/log/httpd/access_log combined
# Set to one of: Full | OS | Minor | Minimal | Major | Prod
ServerTokens Full
ServerSignature On
Alias /icons/ "/var/www/icons/"
<Directory "/var/www/icons">
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<Directory "/var/www/cgi-bin">
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
IndexOptions FancyIndexing VersionSort
# AddIcon* directives tell the server which icon to show for different
# files or filename extensions. These are only displayed for
# FancyIndexed directories.
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
# DefaultIcon is which icon to show for files which do not have an icon
# explicitly set.
DefaultIcon /icons/unknown.gif
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
# DefaultLanguage en
AddLanguage ca .ca
AddLanguage cs .cz .cs
AddLanguage da .dk
AddLanguage de .de
AddLanguage el .el
AddLanguage en .en
AddLanguage eo .eo
AddLanguage es .es
AddLanguage et .et
AddLanguage fr .fr
AddLanguage he .he
AddLanguage hr .hr
AddLanguage it .it
AddLanguage ja .ja
AddLanguage ko .ko
AddLanguage ltz .ltz
AddLanguage nl .nl
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage pt-BR .pt-br
AddLanguage ru .ru
AddLanguage sv .sv
AddLanguage zh-CN .zh-cn
AddLanguage zh-TW .zh-tw
LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
ForceLanguagePriority Prefer Fallback
AddDefaultCharset ISO-8859-2
AddCharset ISO-8859-1 .iso8859-1 .latin1
AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
AddCharset ISO-8859-3 .iso8859-3 .latin3
AddCharset ISO-8859-4 .iso8859-4 .latin4
AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
AddCharset ISO-2022-JP .iso2022-jp .jis
AddCharset ISO-2022-KR .iso2022-kr .kis
AddCharset ISO-2022-CN .iso2022-cn .cis
AddCharset Big5 .Big5 .big5
# For russian, more than one charset is used (depends on client, mostly):
AddCharset WINDOWS-1251 .cp-1251 .win-1251
AddCharset CP866 .cp866
AddCharset KOI8-r .koi8-r .koi8-ru
AddCharset KOI8-ru .koi8-uk .ua
AddCharset ISO-10646-UCS-2 .ucs2
AddCharset ISO-10646-UCS-4 .ucs4
AddCharset UTF-8 .utf8
# See http://www.iana.org/assignments/character-sets
AddCharset GB2312 .gb2312 .gb
AddCharset utf-7 .utf7
AddCharset utf-8 .utf8
AddCharset big5 .big5 .b5
AddCharset EUC-TW .euc-tw
AddCharset EUC-JP .euc-jp
AddCharset EUC-KR .euc-kr
AddCharset shift_jis .sjis
AddType application/x-tar .tgz
AddType application/x-httpd-php .inc .php .php4 .php3 .phtml
AddType application/x-httpd-php-source .phps
# AddEncoding allows you to have certain browsers uncompress
# information on the fly. Note: Not all browsers support this.
# Despite the name similarity, the following Add* directives have nothing
# to do with the FancyIndexing customization directives above.
#AddEncoding x-compress .Z
#AddEncoding x-gzip .gz .tgz
# If the AddEncoding directives above are commented-out, then you
# probably should define those extensions to indicate media types:
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
AddHandler imap-file map
AddHandler type-map var
AddType text/html .shtml
AddOutputFilter INCLUDES .shtml
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
BrowserMatch "^WebDrive" redirect-carefully
BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully
BrowserMatch "^gnome-vfs" redirect-carefully
#<Location /server-status>
# SetHandler server-status
# Order deny,allow
# Deny from all
# Allow from .example.com
#</Location>
#<Location /server-info>
# SetHandler server-info
# Order deny,allow
# Deny from all
#</Location>
<IfModule mod_ssl.c>
Include conf/ssl.conf
</IfModule>
#Start DirectAdmin Settings
Alias /config /var/www/html/redirect.php
Alias /phpMyAdmin /var/www/html/phpMyAdmin/
Alias /phpmyadmin /var/www/html/phpMyAdmin/
Alias /webmail /var/www/html/webmail/
Alias /squirrelmail /var/www/html/squirrelmail/
ErrorDocument 400 /400.shtml
ErrorDocument 401 /401.shtml
ErrorDocument 403 /403.shtml
ErrorDocument 404 /404.shtml
ErrorDocument 500 /500.shtml
#All NameVirtualHost lines are in this file
#Don't remove this line or apache will generate errors.
Include /etc/httpd/conf/ips.conf
LogFormat "%b \"%r\"" homedir
#The default site for the server.
<VirtualHost MyIP:80>
ServerAdmin webmaster@localhost
AliasMatch ^/~([^/]+)(/.*)* /home/$1/public_html$2
DocumentRoot /var/www/html
ServerName localhost
ScriptAlias /cgi-bin/ /var/www/cgi-bin/
CustomLog /var/log/httpd/homedir.log homedir
</VirtualHost>
<VirtualHost MyIP:443>
SSLEngine on
SSLCertificateFile /etc/httpd/conf/ssl.crt/server.crt
SSLCertificateKeyFile /etc/httpd/conf/ssl.key/server.key
</VirtualHost>
I have this in logs after installation and add suPHP :/[Sun Mar 19 20:59:50 2006] [error] Script (/home/XXXXX/domains/XXXXX/public_html/m.php) is writeable by others
