1024solutions
- Jul 19, 2004
What is the latest version of this tool right now?
Hello,1024solutions said:What is the latest version of this tool right now?
That's a feasible development path, but I'm not so sure this tool will benefit from residence as a DA plugin. Give this tool a run and let me know what you think.nate said:Is there a way to make this into a module in directadmin admin level so that it is nice and smooth ?
As far as I know, all listed is 100% working provided my instructions are followednate said:Is there any update on this tool version ? What are the known bugs still ?
Good luck I'm here to help if need arises.nate said:Sorry to be a pain, but I have loads of servers to convert from cpanel to directadmin ... but i need to test it on at least 1 machine first ... lol ..
Any info would be helpfull. Thanks,
-Nathan
Post the real filename you have. GUI backups made from /frontend/x/backup/fullbackup.html are working for me.xcensus said:Seems the resulting backup-usrname-date.tar.gz from GUI backups needs to be renamed to the account username.tar.gz before DA will allow you to import it.
badr said:Hi,
The whole thing is very confusing to me and I am not a newbie. I have a reseller account on cpanel and one on DA. I want to move some accounts over from cpanel to DA and this is what I did, where did I go wrong?
1- create account in DA with the same username and password
No need, just restore the cpanel converted file to any reseller you have created on the DA server using User Backups.
2- create backup with cpanel GUI tool and ftp it to home directory on DA
Yup
3- upload the transfert script to the DA account after editing the .conf file
Create a directory called import, export, move the cpanel backup into import, then execute perl da.directadmin.pl (cant remember its proper name lol) and you will have the fully converted file in export.
4- can't access the transfert script from http
Copy the exported file to the resellers directory, user_backups and then restore the backup.
hmm where did I screw up?
P.S: I can donate a copy of a backup if you still need one to experiment on
thanks
That is just what this script doesjumonjii said:What if you just want to transfer users from Cpanel to DA?
