Hi.
For SpamBlocker 3 (3.2.6a-RC).
Please open your exim.conf and find this block:
Add before:
Hope this help.
FYI. This is not tested by me, for now i use "simple" selective greylisting without any external soft or daemons.
I was going to set this up as suggested by snk and realized there are some differences because I am using spamblocker 3. Can anyone make some suggestions on what modifications needs to be made for spamblocker 3?
I have the current greylisted installed I just need the changes for exim.conf.
# ACCEPT EMAIL BEGINNING HERE
# accept if address is in a local domain as long as recipient can be verified
accept domains = +local_domains
endpass
message = "Unknown User"
verify = recipient
Add before:
# Perform greylisting.
defer message = $sender_host_address is greylisted. Please try again later.
log_message = greylisted.
domains = +relay_domains : +local_domains
!senders = : postmaster@*
!hosts = : +relay_hosts : \
${if exists {/etc/greylistd/whitelist-hosts}\
{/etc/greylistd/whitelist-hosts}{}} : \
${if exists {/etc/virtual/whitelist-hosts}\
{/etc/virtual/whitelist-hosts}{}}
verify = recipient/callout=5s,use_sender,defer_ok
condition = ${readsocket{/var/run/greylistd/socket}\
{--grey $sender_host_address $sender_address $local_part@$domain}{5s}{}{false}}
Hope this help.
