Guide for installing Mailman with DirectAdmin
Is mailman a workable alternative on da?
Yes.....I run multiple lists on multiple domains with the configuration described in this thread.
I would hope it would become a choice in the Control Panel, rather than
having to set it up manually.
Thom
On my CentOS box o got huge errors about mussing things and stuff, I never made it running.
I have gotten most of the way with this install however I am getting the following errors;
/etc/init.d/mailman start
Starting mailman: Traceback (most recent call last):
  File "/usr/local/mailman/bin/mailmanctl", line 106, in ?
    from Mailman import mm_cfg
  File "/usr/local/mailman/Mailman/mm_cfg.py", line 53
    DEFAULT_EMAIL_HOST = 'dxmhosting.com'
SyntaxError: invalid syntax
Needless to say I have something configured wrong there but not exactly sure what it is
Second thing I am getting is this when I browse to http://dxmhosting.com/mailman
Mailman CGI error!!!
The Mailman CGI wrapper encountered a fatal error. This entry is being stored in your syslog:
Group mismatch error.  Mailman expected the CGI
wrapper script to be executed as group "mailman", but
the system's web server executed the CGI script as
group "admin".  Try tweaking the web server to run the
script as group "mailman", or re-run configure,
providing the command line option `--with-cgi-gid=admin'.
Something here that I am not quite grasping, basically what file should those entries be inserted into or do I need to create a new file for those entries and where do I install them?
test:              "|/usr/local/mailman/mail/mailman post test"
test-admin:        "|/usr/local/mailman/mail/mailman admin test"
test-bounces:      "|/usr/local/mailman/mail/mailman bounces test"
test-confirm:      "|/usr/local/mailman/mail/mailman confirm test"
test-join:         "|/usr/local/mailman/mail/mailman join test"
test-leave:        "|/usr/local/mailman/mail/mailman leave test"
test-owner:        "|/usr/local/mailman/mail/mailman owner test"
test-request:      "|/usr/local/mailman/mail/mailman request test"
test-subscribe:    "|/usr/local/mailman/mail/mailman subscribe test"
test-unsubscribe:  "|/usr/local/mailman/mail/mailman unsubscribe test"
They go in the alias file for the domain in /etc/virtual
Cannot configure httpd with mailman
Hi
I've tried to install mailman following the guide a coulpel of time but the main problem is the I cannot access the domain.com/mailman/ folder I got a 403 Error
the strange is that I can access :
domain.com/mailman_images/
domain.com/mailman/archives/
I've checked and fixed the file permission with the /usr/local/mailman/bin/check_perms and everithing is all right.
if I try to access the listinfo script I got the a 500 error and the following suexec log
uid: (501/admin) gid: (501/admin) cmd: listinfo
directory is writable by others: (/usr/local/mailman/cgi-bin)
I think it is a http configuration isse, but I cannot solve it
what can be the problem ???
well..... it turned out that for mailman with suexec that file permission should be different:
all mailman and cgi-in directory should be 755 so not writables for others
and the scripts inside cgi-bin shuld not have the setuid turned on
so
chmod 755 /usr/local/mailman/cgi-bin
chmod 755 /usr/local/mailman/cgi-bin/*
chmod a-s /usr/local/mailman/cgi-bin/*
What would it take to get some assistance setting this up? Feel free to PM me... im kinda frustrated
[root@207612 extra]# service mailman start
  File "/usr/local/mailman/Mailman/mm_cfg.py", line 54
    add_virtualhost(mailman.blitz-hosts.com, blitz-hosts.com)
Grumble Grumble...
It tells you exactly whats wrong. You proabably didnt put single quotes around your hosts.
We still continue not to use Mailman with suexec enabled?
Today I re-read the four pages of this thread, I have returned to perform all the steps carefully, I looking for more information on Google and I always get the same error ...
500 Server error!
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: listinfo
suexec.log
[2012-06-11 20:46:27]: uid: (501/admin) gid: (502/admin) cmd: listinfo
[2012-06-11 20:46:27]: target uid/gid (501/502) mismatch with directory (492/492) or program (492/492)
CentOS 6.2
Thank
I want to install MailMan on FreeBSD. I've noticed this tutorial is from 2008. I wonder how actual it is?
Follow me, Weird its the same. Make sure you are using the right kind of quote ' not `. Or else you can use "
Authenticaton issue
Hello everybody. I've been using DirectAdmin custombuild for years (since 2008 I believe), and I've learned a lot reading this forum over the years. But now I had to register because I'm running into an issue that I can't seem to find a solution to, so I decided to ask for your help:
I've installed Mailman (because of Majordomo's trouble with Yahoo's DMARC), following this guide, on my VPS running CentOS 6.6 and DA 1.46.3. I had to configure mailman without suexec, like Yoshua, excepted I had to indicate the user name that goes with my mailing lists' domain name instead of "apache".
The issue I'm having now is with authentication in Exim, not sure whether it's Mailman- or Exim-related: Whenever I send a message to one of my Mailman list, I get H=localhost (my_server's_rDNS_name) [::1] F=<list_name-bounces@list's_domain_name> rejected RCPT <list_member's_mail_address (not local)>: authentication required in my Exim logs. Only local list members get the messages.
The only workaround I found so far is adding list_name-bounces@list's_domain_name to Exim's whitelist_senders file (I'm using SpamBlocker 4.2.2 for exim.conf). But I feel this it not a secure way to go, because these whitelisted adresses can be spoofed, so I'd like to find the real cause and solution to this authentication issue. I'm certainly missing something in Exim's configuration, but I can't see what. Any ideas?
Thanks a lot in advance.
You're right; that's not a good idea; workaround can open up a hole big enough to drive a truck full of spam through it.
Mailman is trying to relay, but it's not authenticating as a user.
That's all I can tell you because I'm not familiar ehough with Mailman. Hopefully someone else, who is, will also respond.
I'm having the same issue. Did you ever find a better answer than whitelisting the [email protected] address?
Old thread having the same issue
moved mailmain from centos5 which it worked just fine to centos7
could not get mailman to authenticate
I'm running DirectAdmin version v1.61.5 with Custombuild v2.0 and Apache v2.4.46, and there seems to be no way to make Mailman's Web GUI work with suexec enabled in that configuration (though Mailman cohabitated well with DirectAdmin for years on my servers). So I'd like to know whether there is a way to compile Apache 2.4 without suexec under DirectAdmin. Or maybe downgrade Apache or Directadmin? Deleting suexec options in /usr/local/directadmin/custombuild/configure/ap2/configure.apache ends up in compiling errors, but maybe changing the "--with-suexec-caller=apache" or the "--with-suexec-userdir=public_html" settings could be useful?
Any ideas or hints?
