THAT did actually do the trick. Thanks Martynas (and Chirpy!)Have you tried a fresh install?
Okay, I've done a fresh install, and I see it in the plugin manager, but I don't have a link in the admin interface. Did I do something wrong?
Then you must edit all files (.txt) and change the email address.Code:- Login as root - cd /etc/csf - type "for file in *.txt ; do nano $file -w ; done" in the shell
Safe and restart csf/lfd
Paste your 'TCP_IN', 'TCP_OUT', 'UDP_IN', 'UDP_OUT'. Maybe you have removed port 80I'm a real newbie. I just installed per your recommendations and made your recommended changes, however once I turn it on, it blocks all http access. What did I do wrong. Right now, I turned it off so I have access and my sites are accessible. I've installed it on a VPS with DA.
Scott
[I]Warning: The Latest version of CSF does not work properly with DirectAdmin on CentOS 5 machines with Apache 2+[/I]
