ldjnetworks
- Apr 23, 2005
I have a problem with Exim, I tried searching around here but I didn't find anyone with a similar issue. When I try and send email to an address on the server it bounces back with
On further inspection of exim mainlog I see this:
So I take a look in exim.conf for domain_filter and I have this
That looks ok to me so I ran
/usr/local/directadmin/scripts/set_permissions.sh
That had no effect. I found a google blog with a fix which says to set the suid bit on the exim binary, but it is already set.
Any help would be appreciated.
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
[email protected]
retry timeout exceeded
2009-02-17 16:39:44 1LZYbO-0004cV-Tw => [email protected] F=<> R=lookuphost T=remote_smtp S=2711 H=gmail-smtp-in.l.google.com [209.85.133.114] C="250 2.0.0 OK 1234910384 c14si9008912ana.21"
2009-02-17 16:39:44 1LZYbO-0004cV-Tw Completed
2009-02-17 16:50:29 1LZXjm-0002eo-LM unable to set gid=12 or uid=506 (euid=8): domain_filter router (recipient is [email protected])
2009-02-17 16:50:29 1LZXjm-0002eo-LM internal problem in domain_filter router (recipient is [email protected]): failure to transfer data from subprocess: status=0100 readerror='Success'
2009-02-17 16:50:29 1LZXjm-0002eo-LM == [email protected] R=domain_filter defer (-1): internal problem in domain_filter router (recipient is [email protected]): failure to transfer data from subprocess: status=0100 readerror='Success'
domain_filter:
driver = redirect
allow_filter
no_check_local_user
condition = "${if exists{/etc/virtual/${domain}/filter}{yes}{no}}"
user = "${lookup{$domain}lsearch{/etc/virtual/domainowners}{$value}}"
group = "mail"
file = /etc/virtual/${domain}/filter
directory_transport = address_file
pipe_transport = virtual_address_pipe
retry_use_local_part
no_verify
