RoundCube Webmail 0.3-stable
Roundcube Password plugin
I spent a little while figuring this out. On one of my servers, trying to use the change password plugin would just result in a blank browser page, and a segfault error in /var/log/httpd/error.log
The problem:
Password plugin is confiugred in/var/www/html/roundcube/plugins/password/config.inc.php
First, this must be set near the top:
 $rcmail_config['password_driver'] = 'directadmin';
Then these two settings are used to tell it how to connect to DA
$rcmail_config['password_directadmin_host'] = 'tcp://localhost';
$rcmail_config['password_directadmin_port'] = 2222;
However if your DirectAdmin is SSL-enabled, you must change the first line there to be:
$rcmail_config['password_directadmin_host'] = 'ssl://localhost';
