Results 1 to 3 of 3
Thread: DA - An error has occurred while trying to update the software
  1. #1
    Join Date
    Aug 2007
    Antipolo City, Rizal, Philippines (a British National)
    Posts
    144
    Exclamation DA - An error has occurred while trying to update the software
    Hi Chaps,
    I noticed that my VPS provider seemed to be having trouble updating the license file (I got a couple of messages from the message system to inform me of errors during the update), so I thought I would help them out by making sure that I'm using the most up to date software. Boy, was that a mistake!
    When I tried to update DA from within DA, after a few minutes, I received the following message in the message system.
    Subject: *** An error has occurred while trying to update the software *** Today at 07:05
    This is an automated message notifying you that an error has occurred while trying to update the software.
    The generated error message is as follows:
    Error restoring file /usr/local/directadmin/update.tar.gz :
    gzip: stdin: not in gzip format
    /bin/tar: Child returned status 1
    /bin/tar: Error exit delayed from previous errors
    : tar returned error code 512<br>
    <br>
    <br>
    Try updating manually: http://help.directadmin.com/item.php?id=29<br>
    Please contact JBMC-Software, including the error message. Failure to do so could result in an inactive control panel.
    This is really worrying as I'm in the Philippines right now but due to fly to UK tonight, so won't have much chance to fix this if it goes down. Does anyone have any ideas please?
    Kind regards,
    Peter
    Kind regards,
    pete.
    My Server Details
    I'm running a VPS provided by Serverpoint.com.
    The VPS has a Parallels Power Panel - Virtuozzo Container manager and the OS is CentOS 5.0
  2. #2
    Join Date
    Mar 2005
    Posts
    5,276
    If the DirectAdmin license is provided by Serverpoint.com then they are the ones that will need to fix it.
    Floyd Morrissette Little Creek Hosting
    Web Hosting Solutions. Virtual Private Servers
    DirectAdmin Administration and Support
    Our focus is on quality customer support
  3. #3
    Join Date
    Jun 2003
    California
    Posts
    26,122
    Just to help everyone's comfort zone: If DirectAdmin fails the hosting stack will still continue to run.
    And to amplify a bit on what Floyd writes: That message generally means that your server didn't get a valid updte tarball, but an error message.
    +1 951 643-5345
    Third-Party DirectAdmin administration and support
    Dedicated Servers, Dedicated Reseller Accounts
    NoBaloney Internet Services div. Qnito Incorporated
    848 North Rainbow Blvd., Suite #3789
    Las Vegas, NV 89107-1103
Similar Threads
  1. Subject: *** An error has occurred while trying to update the software ***
    By seachen in forum System-Level Technical Discussion
    Last Post: 01-26-2011, 12:05 AM
  2. An error has occurred while trying to update the software
    By ssi.inc in forum DirectAdmin Version Updates
    Last Post: 12-02-2009, 02:47 PM
  3. Subject: An error occurred during the backup (mysqldump error output)
    By seachen in forum Reseller-Level Difficulties
    Last Post: 08-27-2008, 02:14 PM
  4. Can DA be used to update server software?
    By cyPHunk in forum General Technical Discussion & Troubleshooting
    Last Post: 08-08-2007, 01:05 PM
  5. do you need to update other software installed by DA or ?
    By jt2377 in forum DirectAdmin General Discussion
    Last Post: 03-09-2006, 04:31 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
