Backup restore error
winger
Rio de Janeiro - Brasil
hello,
I get this error when I try to restore a backup in a new server:
Domain Created Successfully
Error connecting to MySQL: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
any help to fix that?
thanks!
From SSH
/etc/init.d/mysqld status
If it shows something like:
SUCCESS! MySQL running (1070)
MySQL is at least running, so you might want to check your mysql logs (usually in /var/log/mysqld.log).
If it does not, you could try:
/etc/init.d/mysqld restart
And try the status step again. If it shows MySQL is running, try adding the domain again.
hello,
[root@srv8 /]# /etc/init.d/mysqld status
ERROR! MySQL is not running, but lock exists
[root@srv8 /]# /etc/init.d/mysqld restart
ERROR! MySQL manager or server PID file could not be found!
lsof | grep mysql
In addition, could you post your /etc/my.cnf as an .txt attachement?
You might also want to try and remove the lock
rm -rf /var/lock/subsys/mysql
I just add to the /etc/my.cnf file with the following data:
[mysqld]
socket=/var/lib/mysql/mysql.sock
now I get:
[root@srv8 etc]# /etc/init.d/mysqld status
SUCCESS! MySQL running (11425)
