Installing DKIM with DA Exim 4.71
Just in the last warn section or all? And in case is yes, why just the last?
        warn    add_header      = X-DKIM-Status: $dkim_verify_status [($dkim_cur_signer) - $sender_host_address]
                sender_domains  = $sender_address_domain:$dkim_signers
                dkim_signers    = $sender_address_domain:$dkim_signers
                dkim_status     = invalid
                condition       = ${if eq {${lc:$dkim_verify_status}{invalid}{true}{false}}}
                dkim_status     = fail
                condition       = ${if eq {${lc:$dkim_verify_status}{fail}{true}{false}}}
                dkim_status     = none
                condition       = ${if eq {${lc:$dkim_verify_status}{none}{true}{false}}}
                dkim_status     = pass
                condition       = ${if eq {${lc:$dkim_verify_status}{pass}{true}{false}}}
        accept
Regards
All of them
EDIT: This script seems very verbose, check the official doc for a simpler way
http://www.exim.org/exim-html-curre...port_for_dkim_domainkeys_identified_mail.html
You can simply use
dkim_status = fail
instead of
Thanks, i'll check all of them.
Regarding the fail condition, well i'm not too sure how to change it so i'll keep it this way :)
Regards
