But the mod_fcgid is problem is still exist. Any idea?
I use php 5.3.10 cli apache 2.4.1 but get this error in restart apache
Starting httpd: [Fri Mar 02 22:16:47.465149 2012] [core:warn] [pid 9788] AH00117: Ignoring deprecated use of DefaultType in line 60 of /etc/httpd/conf/httpd.conf.
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/httpd/conf/ips.conf:6
Failed loading /usr/local/lib/ZendGuardLoader.so: /usr/local/lib/ZendGuardLoader.so: undefined symbol: compiler_globals
I do this but I get error yet
1) re-configure with apache with prefork mode , by default it was worker mode.
2) add two parameter for php configure
--disable-maintainer-zts
--disable-safe-mode
I run command php -v and get this errors:
I got the following error with CB 1.2.31 .
Starting httpd: httpd: Syntax error on line 18 of /etc/httpd/conf/httpd.conf: Cannot load /usr/lib/apache/libphp5.so into server: /usr/lib/apache/libphp5.so: undefined symbol: ap_log_rerror
./build php n
It does not. PHP 5.3.10 and PHP 5.4.0 have problems with Apache 2.4.x. Patches for them will be included into the CustomBuild scripts today.zend guard loader have problem with apache 2.4.x
https://bugs.php.net/bug.php?id=61172
Fatal error: session_start() [<a href='function.session-start'>function.session-start</a>]: Failed to initialize storage module: files (path: ) in /var/www/html/phpMyAdmin-3.4.10.1-all-languages/libraries/session.inc.php on line 92
