## Dovecot 2.0 configuration file
#IPv4
#listen = *
#IPv4 and IPv6:
#listen = *, ::
protocols = imap pop3 lmtp sieve
########### SSL ###########
service imap-login {
inet_listener imap {
address = *, ::
port = 143
inet_listener imaps {
address = *
port = 993
ssl = yes
service_count = 1
service pop3-login {
inet_listener pop3 {
address = *
port = 110
inet_listener pop3s {
address = *
port = 995
ssl = yes
######### End #################
auth_username_chars = abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890.-_@&
auth_verbose = yes
disable_plaintext_auth = yes
login_greeting = Dovecot DA ready.
mail_access_groups = mail
default_login_user = dovecot
mail_location = maildir:~/Maildir
passdb {
driver = shadow
passdb {
args = username_format=%n /etc/virtual/%d/passwd
driver = passwd-file
service auth {
user = root
unix_listener auth-master {
user = mail
group = mail
mode = 0664
process_min_avail = 16
user = dovecot
user = dovecot
# default namespace
namespace {
separator = .
prefix = INBOX.
inbox = yes
type = private
list = yes
subscriptions = yes
######### Auto create folders and subscribe ##########
mailbox Drafts {
auto = subscribe
special_use = \Drafts
mailbox Junk {
auto = subscribe
special_use = \Junk
mailbox Sent {
auto = subscribe
special_use = \Sent
mailbox Trash {
auto = subscribe
special_use = \Trash
mailbox name {
special_use = \Drafts \Junk \Sent \Trash
######### End ########################################
#ssl = yes
ssl_cert = </etc/httpd/conf/ssl.crt/server.crt
ssl_cipher_list = ALL:!ADH:RC4+RSA:+HIGH:+MEDIUM:-LOW:-SSLv2:-EXP
ssl_key = </etc/httpd/conf/ssl.key/server.key
userdb {
driver = passwd
userdb {
verbose_proctitle = yes
protocol pop3 {
pop3_uidl_format = %08Xu%08Xv
pop3_logout_format = top=%t/%p, retr=%r/%b, del=%d/%m, size=%s, bytes=%i/%o
protocol imap {
mail_max_userip_connections = 1024
service managesieve-login {
inet_listener sieve {
port = 4190
service_count = 1
vsz_limit = 64M
service managesieve {
process_limit = 10
protocol sieve {
managesieve_max_line_length = 65536
managesieve_implementation_string = dovecot
log_path = /var/log/dovecot-sieve-errors.log
info_log_path = /var/log/dovecot-sieve.log
plugin {
sieve = ~/.dovecot.sieve
sieve_global_path = /var/lib/dovecot/sieve/default.sieve
sieve_dir = ~/sieve
sieve_global_dir = /var/lib/dovecot/sieve/global/
# Which Sieve language extensions are available to users. By default,
# all supported extensions are available, except for deprecated
# extensions or those that are still under development. Some system
# administrators may want to disable certain Sieve extensions or
# enable those that are not available by default. This setting can
# use '+' and '-' to specify differences relative to the default.
# For example `sieve_extensions = +imapflags'' will enable the
# deprecated imapflags extension in addition to all extensions
# enabled by default.
sieve_extensions = +spamtest +spamtestplus
sieve_spamtest_status_type = text
sieve_spamtest_status_header = X-Spam-Status
sieve_spamtest_text_value1 = No
sieve_spamtest_text_value10 = Yes
protocol lda {
mail_plugins = $mail_plugins sieve
postmaster_address =
[email protected]
hostname = server.hostname.com
auth_socket_path = /var/run/dovecot/auth-master
log_path = /var/log/dovecot-lda-errors.log
info_log_path = /var/log/dovecot-lda.log
protocol lmtp {
log_path = /var/log/dovecot-lmtp-errors.log
info_log_path = /var/log/dovecot-lmtp.log
