AndyII
- Oct 3, 2006
I too have always wondered just how well maldet did, I have had my favorite WP plugin find something in a WP site that maldet never picked up on, that plugin , which many scorn because it hasnt been updated in over 2 years, BUT it still works as good as it did when it first was released, why it works is that it does Not depend on WP core to function
over the years I have had the pleasure or, misfortune of trying many themes that were encoded, many are just a credit link to the author and that is fine, its the ones that have embedded links to places that are not favorable. I know this because I have decoded some just to see what was going on, the protected author link is fine, the others are not acceptable, most of the time it is a simple task, even for me, to remove the footer code and or comment out the function that checks the footer, Is this ethical? No I dont recommend it but I was curious as to why a free theme would need to be protected.
the conclusion.... Stay Away From Free Themes that You cant trust with having been encoded some how, many ARE malicious and cause troubles.
As for maldet? Im still wondering if its even worth the troubles of using it
JMHO
JMHO
