Results 1 to 2 of 2
Thread: A failure in the SSL library occurred
  1. #1
    Join Date
    Apr 2011
    Posts
    7
    I'm running DirectAdmin over SSL and I'm getting the following errors in the DirectAdmin error log.
    Can't connect to ssl!
    -> A failure in the SSL library occurred, usually a protocol error.
    -> error:00000001:lib(0):func(0):reason(1)
    Socket write error: fd is connected to a pipe or socket whose reading end is closed.  When this  happens the writing process will also receive a SIG_PIPE signal.  (Thus, the write return value is seen only if  the program catches, blocks or ignores this signal.)
    The server runs CentOS release 5.10 (Final).
    Any idea what is causing this and how to fix this?
  2. #2
    Join Date
    Aug 2008
    Posts
    4,695
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
