Installing DirectAdmin on Google Compute Engine VM
ORiN
Singapore
I am exploring cloud solutions for a client and is exploring if it is possible to install DirectAdmin on Google's Compute Engine. Anyone with similar experience?
I figured that since the VM can run CentOS, I should be able to install DirectAdmin.
I have no experience with it. The purpose of my reply is to point out some of the issues you may run into:
1) does the instance stay connected? Are there any circumstances under which it could disappear? If so does any of its storage disappear with it? if so, then do you have a way to completely backup your virtual bare-metal system?
2) do you have pass through access to one or more static IPs? I seem to recall that Amazon has or at least had a problem with this. There was a workaround, but it may not be officially supported by DirectAdmin.
Perhaps you can give it a try and let us know.
To answer your questions, the instance is supposed to stay connected as it is used to host some websites and a web application. My server admin is using a static IP for the VM.
Looks like my server admin will have to try on his own for now. I will report back with some of our findings.
It looks like Google Compute Engine has the same issues as Amazon even if the external IP is pointing to the network address. Given that cloud solutions are getting more and more common, this is extremely frustrating.
What does the word cloud mean to you?
The Google Compute Engine, just as the Amazon Web Service, is a specialized kind of cloud solution, designed for on-demand hosting. It's a solution in the cloud whre the word cloud refers to that good old standby most of us call the Internet.
Many software systems require pass-through IP solutions for license control. I recall reading a work-around which enables DirectAdmin to work on AWS, and the same might very well work with Google Comute Engine.
But I still consider them both specialized platforms for on-demand computing rather than solutions designed for hosting.
So what would I consider a cloud solution designed for hosting? A Dedicated Server. A VP Server.
That's just me. Your mileage may vary.
I tried a few times to install DA on Google Cloud Platform Compute Engine. After a lot of Google search and this post. I looked up the workaround of DA to run on AWS. Since the two platforms are not configured in the same way this process was trial and error. So the success to install the script without connection errors was after. I first connected as root with the command:
sudo -s
Next, stop the Firewall
systemctl mask firewalld
systemctl stop firewalld
Then I followed on CentOS 7, xfs is used by default and Quotas are not activated, so you need to enable them manually
nano /etc/default/grub
add quota options rootflags=usrquota,grpquota into the end of GRUB_CMDLINE_LINUX line, it will look like this
GRUB_CMDLINE_LINUX="crashkernel=auto console=ttyS0,38400n8 rootflags=usrquota,grpquota"
Make a backup
cp /boot/grub2/grub.cfg /boot/grub2/grub.cfg.back
Generate a new configuration file:
grub2-mkconfig -o /boot/grub2/grub.cfg
Restart the server, the root directory will be mounted with required options. We can check by running this command
mount | grep '/'
/dev/xvda1 on / type xfs (rw,relatime,attr2,inode64,usrquota,grpquota)
Add network eth0:0
By default, GCP use private IP for eth0, to install DirectAdmin, we need to use the public IP
nano /etc/sysconfig/network-scripts/ifcfg-eth0:0
Enter the following content
DEVICE=eth0:0
BOOTPROTO=none
ONPARENT=yes
IPADDR=xxx.xxx.xxx.xxx
NETMASK=255.255.255.0
ONBOOT=yes
where xxx.xxx.xxx.xxx is your AWS Public IP, then restart the network
/etc/init.d/network restart
If you wish to you IPv6, set your eth0 live below:
IPV6INIT="yes"
IPV6ADDR=2600:1f16:xxxxxxxxxxxx
6. Setup DirectAdmin
echo 1 > /root/.lan
wget http://www.directadmin.com/setup.sh
chmod 755 setup.sh
./setup.sh
And follow the instructions. Note when you asked for the network, enter eth0:0
Configuration
Since GCP run on a LAN/NAT and behind the firewall, we need to do some config.
Enable LAN
nano /usr/local/directadmin/conf/directadmin.conf
Add this value lan_ip=yyy.yyy.yyy.yyy where yyy.yyy.yyy.yyy is your GCP Private IP
Link the Private IP to your Public IP using the DA Linked IP feature
  • Add the LAN IP to DA's IP manager. Don't assign it to any Users or Domains.
  • View the details of the external IP: Admin Level -> IP Manager -> Click the public/external IP.
  • Link the internal IP to the external IP: Select the LAN IP from the drop down.
  • Only select Apache, do not select DNS
Restart DirectAdmin
Open ports for FTP
I like to use (https://www.configserver.com/cp/csf.html) to manage my firewall settings on command line and via DA.
If you use ProFTPD, edit it's configure file:
nano /etc/proftpd.conf
Add after PassivePorts: MasqueradeAddress xxx.xxx.xxx.xxx where xxx.xxx.xxx.xxx is your AWS Public IP
Add rule to the iptables
iptables -I INPUT -p tcp --dport 35000:35999 -j ACCEPT
nano /usr/libexec/iptables/iptables.init
add $IPTABLES -A INPUT -p tcp --dport 35000:35999 -j ACCEPT below the ftp section, like this
# ftp
$IPTABLES -A INPUT -p tcp --dport 21 -j ACCEPT
I compile this how to from several different sites and merged them into one which I use get my instance running with DA. My only issue is I am not sure how fix any issues that maybe caused when the instance reboots. Both AWS and GCP reset the hostname to their system default. There is suppose to be a way to set this at boot but I think you have to make a bash script then call to it at boot using the execute script option on both cloud platforms.
i can't add quota. This is my /etc/default/grub
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=true
GRUB_TERMINAL="serial console"
GRUB_SERIAL_COMMAND="serial --speed=38400"
GRUB_DISABLE_RECOVERY="true"
but when check with mount | grep ' / ' then
[root@sv2 ~]# mount | grep ' / '
/dev/sda2 on / type xfs (rw,relatime,seclabel,attr2,inode64,noquota)
