AndyII
- Oct 3, 2006
Im not positive what version I have installed, was 114 or earlier..
I sort of gave up when the license check kept failing and only looked again when SeLLeRoNe was posting about the random code not generating , I then went and switched skins on a test account to see if it worked on the version I had....
now the license check did not fail and was able to test the random password for the mysql database
this skin needs to be made so any reseller can install the skin without having to ask the the root man to do something on folder/file permissions....unless this was already solved
