Results 1 to 8 of 8
Thread: agian "/usr/local/directadmin/data/task.queue is growing in size " problem
  1. #1
    Join Date
    May 2011
    Posts
    22
    Hi guys,
    I'm getting this error many times after DA update.
    DirectAdmin has noticed that the file /usr/local/directadmin/data/task.queue is growing in size and not getting processed.
    Please see this guide to ensure that your task.queue gets properly processed:
    http://help.directadmin.com/item.php?id=107
    i followed and did mentioned commands in above link but no chance.
    Here is the Server Details:
    Compiled on	CentOS 7.0 64-Bit
    Compile Date	Feb 21 2016, 03:50:52
    Server Version	1.50.0
  2. #2
    Join Date
    Apr 2005
    GMT +7.00
    Posts
    13,354
    So do you have crond running? And what do you see in system logs?
    What do you see if you run
    /usr/local/directadmin/dataskq d
    Regards, Alex G.
    - Get the best commercial DirectAdmin support and hire me on poralix.com
    - Follow and like @Poralix on Facebook
  3. #3
    Join Date
    May 2011
    Posts
    22
    Hello zEitEr, you are still one of good supporters of this forum!
    Quote Originally Posted by zEitEr View Post
    # ps ax | grep cron
     7121 ?        Ss     0:00 /usr/sbin/crond -n
    31608 pts/0    S+     0:00 grep --color=auto cron
    No interested things are in system log file,last lines are about shutdown , tickets removing , user actions and so on,
    Segmentation fault
  4. #4
    Join Date
    Apr 2005
    GMT +7.00
    Posts
    13,354
    Thank you.
    And is Directamin running at all? And does license match to your actual OS and you really run CentOS 7?
    Regards, Alex G.
  5. #5
    Join Date
    May 2011
    Posts
    22
    Thank you.
    yes, i can login in to DA panel.
    my FTP dose not work,i can not receive any email from external sites,...
    this server was working without any problem,after license update or DA update those problem were appeared.
    Version:
    cat /etc/*-release
    CentOS Linux release 7.2.1511 (Core)
    NAME="CentOS Linux"
    VERSION="7 (Core)"
    ID="centos"
    ID_LIKE="rhel fedora"
    VERSION_ID="7"
    PRETTY_NAME="CentOS Linux 7 (Core)"
    ANSI_COLOR="0;31"
    CPE_NAME="cpe:/o:centos:centos:7"
    HOME_URL="https://www.centos.org/"
    BUG_REPORT_URL="https://bugs.centos.org/"
    CENTOS_MANTISBT_PROJECT="CentOS-7"
    CENTOS_MANTISBT_PROJECT_VERSION="7"
    REDHAT_SUPPORT_PRODUCT="centos"
    REDHAT_SUPPORT_PRODUCT_VERSION="7"
  6. #6
    Join Date
    May 2011
    Posts
    22
    Still Problem exists.
    Any idea?
  7. #7
    Join Date
    Apr 2005
    GMT +7.00
    Posts
    13,354
    Try manually update DA binaries following this guide: http://help.directadmin.com/item.php?id=29
    Regards, Alex G.
  8. #8
    Join Date
    May 2011
    Posts
    22
    problem solved by manually update,Thank you really
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
