Can't Install DA
mderossett
Hi Folks -
I'm a long-time user of DA, and can usually find help here when I'm having an issue with something. I can't seem to find the answer I am looking for though.
This is a new server deployment - the only thing different for me, is in the past It's always been 32-bit, now I am installing on a 64-bit. On the surface, that shouldn't make any difference though.
I did log into my account to make sure the settings were correct for my version of CentOS, and then that it was set for 64 bit.
Now, I have run all of the pre-install commands, and that all seems to go well. I've even done yum updates. Everytime I try to install DA, I get the following. I see several "no" answers. But when I try to install those, I get the answer that the latest version already exists (I haven't done them all though):
checking size of long... (cached) 8
checking size of int... (cached) 4
checking for int32_t... yes
checking for uint32_t... yes
checking for sys/types.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for string.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for strtoll... yes
checking for atoll... yes
checking for strftime... (cached) yes
checking which regex library to use... php
checking whether to enable LIBXML support... yes
checking libxml2 install dir... /usr/local/lib
checking for xml2-config path... /usr/local/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... yes
checking for Kerberos support... yes
checking whether to use system default cipher list instead of hardcoded value... no
checking for krb5-config... /usr/bin/krb5-config
checking for DSA_get_default_method in -lssl... yes
checking for X509_free in -lcrypto... yes
checking for RAND_egd... no
checking for pkg-config... /usr/bin/pkg-config
checking for PCRE headers location... /usr/local/include
checking for PCRE library location... /usr/local/lib
checking whether to enable the SQLite3 extension... yes
checking bundled sqlite3 library... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... /usr/local/lib
checking for zlib version >= 1.2.0.4... 1.2.3
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... yes
checking for BZip2 support... no
checking whether to enable calendar conversion support... yes
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.19.7
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... cc -E
checking for openssl support in libcurl... no
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... yes
checking for curl_easy_strerror in -lcurl... yes
checking for curl_multi_strerror in -lcurl... yes
checking for QDBM support... no
checking for GDBM support... no
checking for NDBM support... no
checking for TCADB support... no
checking for Berkeley DB4 support... no
checking for Berkeley DB3 support... no
checking for Berkeley DB2 support... no
checking for DB1 support... no
checking for DBM support... no
checking for CDB support... no
checking for INI File support... no
checking for FlatFile support... no
checking whether to enable DBA interface... no
checking whether to enable DOM support... yes
checking for xml2-config path... (cached) /usr/local/bin/xml2-config
checking whether libxml build works... (cached) yes
checking for ENCHANT support... no
checking whether to enable EXIF (metadata from images) support... no
checking for fileinfo support... yes
checking for strcasestr... yes
checking for utimes... yes
checking for strndup... yes
checking whether to enable input filter support... yes
checking pcre install prefix... no
checking whether to enable FTP support... yes
checking OpenSSL dir for FTP... no
checking for GD support... yes
checking for the location of libvpx... no
checking for the location of libjpeg... /usr/local/lib
checking for the location of libpng... /usr/local/lib
checking for the location of libXpm... no
checking for FreeType 2... /usr/local/lib
checking for T1lib support... no
checking whether to enable truetype string function in GD... yes
checking whether to enable JIS-mapped Japanese font support in GD... no
If configure fails try --with-vpx-dir=<DIR>
checking for jpeg_read_header in -ljpeg... yes
checking for png_write_image in -lpng... yes
If configure fails try --with-xpm-dir=<DIR>
configure: error: freetype-config not found.
*** There was an error while trying to configure php. Check the configure file
Stopping crond:                                            [  OK  ]
Starting crond:                                            [  OK  ]
Cannot find /usr/local/bin/php
Please recompile php with custombuild, eg:
./build all d
