im trying to follow the instructions to install php 5 and when Im on the make part i get:
make: *** No targets specified and no makefile found. Stop.
and when I type in make install i get kinda the same but it says:
make: *** No rule to make target `install'. Stop.
any ideas?
when I did the whole /this/that/configure.php part i got:
Configuring extensions
checking whether to enable LIBXML support... yes
checking libxml2 install dir... no
checking for xml2-config path...
configure: error: xml2-config not found. Please check your libxml2 installation.
is libxml2 causing the problem?
if anyone could help that would be great thanks.
any ideas?
