One issue has been found with 'subtheme' inheritance for resellers, already fixed in DA 1.58 RC2 binaries: http://forum.directadmin.com/showthread.php?t=58526
Please try updating it Thank you!
I found a lot of the menu icons went white and couldn't see them?
sub theme only work for admin / session login as admin
but if login with reseller uname & pwd sub theme not display only show default white evolution and no option set up sub theme in skin option
Hello smtalk how to solve this issue when i try run npm run dev in local development for trying build theme starter
a DirectAdmin login page has been show in localhost:8080
but when i fill user and password return back to login form again.
i was try set referrer_check=0 in directadmin.conf but still not fix
May you confirm it's the same with DA 1.58.1? I was unable to reproduce it. It could be that the user has it's own skin-settings saved. Just click "Reset All" in "Skip Options" if that's the case
Compiled on CentOS 7.0 64-Bit
Compile Date Aug 13 2019, 02:16:09
Server Version 1.58.1
Current Available Version 1.581000
Last Updated Tue Aug 13 15:38:37 2019
same with us, has been update to DA latest version but not solved this problem
Did you try 'Reset All'? (I mean "are you sure you don't have non-traditional set in skin preferences of the user?")
Its solve now, we try force redownload packaged again , and now show in sub reseller
now
mkdir -p /usr/local/directadmin/data/users/admin/skin_customizations/evolution/themes
cd /usr/local/directadmin/data/users/admin/skin_customizations/evolution/themes
wget -O traditional.tar.gz https://demo.directadmin.com/download/traditional.tar.gz
tar xzf traditional.tar.gz
you mean redownload subtheme packages ?
its not solved my problem.
Sudah coba dipastikan mas versi nya 1.58.1 ����
