DKIM breaked line
Ana Carolina
Hi! I`m having this problem... trying to use e-goi newsletter system they ask for DKIM config. But the test said the DKIM value is broken line... How to fix it?
Should be like this: v=DKIM1; g=*; k=rsa; p=MIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQDbx9jJyOqr7amc+wtRY1WxKb/8jj4EGEnGNj2kOUAMGBCW3TWWP5T5cDnP3V1rnnAlWn79P1jOIRFiRdwyVPuuHNJqIVhKsHPo5UV39nklDdjs6TfrP0IPGt8QdETP1z6bKBAhBGSRxnQlP3YIeKNOJcjpNoLXsVChWfdwe/K5fwIDAQAB
But it is like this: v=DKIM1; g=*; k=rsa; p=MIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQDbx9jJyOqr7amc+wtRY1WxKb/8jj4EGEnGNj2kOUAMGBCW3TWWP5T5cDnP3V1rnnAlWn79P1jOIRFiRdwyVPuuHN
see?? the space after the PuuHN ...
How can I fix it trought SSH?
You can edit your DKIM key directly in your DirectAdmin interface => DNS management, here you will be able to change everything in your DNS Zone without SSH or command line.
When it's done, I strongly recommand you to check the FULL validity of your DKIM with this test
Long DKIM lines in DNS always get space-separated. You might read more details here: https://serverfault.com/a/255676
If you have issues on validating a DKIM records from e-goi newsletter system, it might be due to the fact you are using a wrong selector in DNS. I guess you've replaced a value for a default x._domainkey record? But your service might require that you use another selector. Check with them.
I can just delete and set a new one. I want to edit the field, to erase the space...
I saw that link... it is something like this... You think this option might work on DA?
"If you are using MySQL/MariaDB as your DNS backend, like PowerDNS you could resize your content column.
Default PowerDNS content length is VARCHAR(255)
So your DKIM signature will be trimmed off to 255 characters
to fix this
just change the content size via the MySQL CLI / MariaDB CLI
mysql -u root -p
USE powerdns;
alter table records modify column content text not null;
restart your DNS Service (eg PowerDNS)
service pdns restart"
example
This is the e-goi error http://b8comunicacao.com.br/imagem/e-goi.png
This is my panel: http://b8comunicacao.com.br/imagem/panel.png
This was the answer from e-goi I translated to english on google so you can understand..... "Thanks for the return.
The information configured on your DKIM is entered correctly, in fact; however, your hosting is propagating this information with a break, as you can confirm from these two external validations: https://cl.ly/281f541dc537, https://cl.ly/1abd91f1cee0
You can also do this validation through the following link:
https://network-tools.com/nslookup/
This is a situation that has to be verified and corrected by your hosting technical support, as we have no control over how your hosting is propagated."
Sorry I was thinking about the interface of DirectAdmin and it seems that we doesn't have the same interface
That's an Evolution skin of DirectAdmin. You can change a skin at a reseller level.
You can try in your admin/reseller Interface
Server Manager => Administrator Settings => Server Settings => Document Root to Demo Skin = ./data/skins/evolution
If you don't want use SSH, you can use a Free "File Explorer" as WinSCP or Filezilla
Your file is located here : /etc/bind/
In this folder you will find the file that you want edit : Your-domain.com.db
But this is not really help if you don't want use SSH ! because you must restart BIND (DNS system) by SSH : "/etc/init.d/bind9 restart" to apply your changes.
Your acces with DA is level user ? or Reseller user ?
I'm reseller... the first option you gave will change the users or the reseller area to evolution too? because I installed the evolution trought the ssh and it not worked so good, the file was missing... but I could be back to enhance trought the reseller level...
do you know ssh code to install the revolution? So i can compare with the one I've testes to check why it was broken....
If you used SSH, why you didn't made this above ? it's done and solved ?
Change the skin is not DKIM problem, you should open a new thread in this case.
Looks like a problem on the system. Please try running DA in debug mode to see what’s the problem.
ebug mode. Level 2000
DirectAdmin 1.52.1
Accepting Connections on port 2222
Sockets::handshake - begin
Sockets::handshake - end
Cannot find first space after where GET or POST should be
/HTM_INDEX_RESELLER
0: Accept-Encoding: gzip, deflate, br
1: Accept-Language: pt-BR,pt;q=0.9,en-US;q=0.8,en;q=0.7,fr;q=0.6,es;q=0.5,la;q=0.4
2: Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3
3: Connection: keep-alive
4: Cookie: mp_f48baf7f57bdb924fc68a786600d844e_mixpanel=%7B%22distinct_id%22%3A%20%22f7282cf462d4bf2849ed651ca8513a12%22%2C%22%24device_id%22%3A%20%2216ccfd5a8f4302-0e01267a6c396e-38637701-13c680-16ccfd5a8f57ab%22%2C%22%24user_id%22%3A%20%22f7282cf462d4bf2849ed651ca8513a12%22%2C%22%24initial_referrer%22%3A%20%22https%3A%2F%2F94.23.2.138%2F~nadiadra%2Fwp-admin%2Fplugins.php%3Fplugin_status%3Dall%26paged%3D1%26s%22%2C%22%24initial_referring_domain%22%3A%20%2294.23.2.138%22%7D; wpglobus-language-old=en; wpglobus-language=en; session=w4gQyJkj2RMA03PgfiZQNrjDfSZd8mj2qOSmhBWjcsrbvEFYwowIfgVJ85wFpdHd
5: Host: 94.23.2.138:2222
6: Referer: https://94.23.2.138:2222/CMD_SKINS
7: Sec-Fetch-Mode: navigate
8: Sec-Fetch-Site: same-origin
9: Sec-Fetch-User: ?1
10: Upgrade-Insecure-Requests: 1
11: User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.90 Safari/537.36
Checking referer https://94.23.2.138:2222/CMD_SKINS to 94.23.2.138:2222
Referer check passed: 94.23.2.138=94.23.2.138 2222=2222
Plugin::addHooks: start
Plugin::addHooks: end
Command::run: finished /HTM_INDEX_RESELLER
/CSS_STYLE
GET string: v=1.52.1&tokenize_css=yes
2: Accept: text/css,*/*;q=0.1
6: Referer: https://94.23.2.138:2222/HTM_INDEX_RESELLER
7: Sec-Fetch-Mode: no-cors
9: User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.90 Safari/537.36
Checking referer https://94.23.2.138:2222/HTM_INDEX_RESELLER to 94.23.2.138:2222
Command::run: finished /CSS_STYLE
I updated the DA sucessfuly. Now the revolution skin work. Updated the DKIM code, lets see if it worked.
