carootcert.pem removed now not regenerating by LetsEncrypt
DewlanceVPS
I removed carootcert.pem and other SSL files from conf file to fix SSL issue.
But now when I use this commands then it does not recreate SSL files inside /usr/local/directadmin/conf/
Error while restarting directadmin: error loading certificate: /usr/local/directadmin/conf/cacert.pem
Thanks.
If you don't get the files re-created then a request you initiate fails with an error. What are the last bottom 10 lines?
When I ran LetsEncrypt commands for hostname then it does not show any error however file does not recreate inside config file.
In last 10 line, It only contain this " error loading certificate: /usr/local/directadmin/conf/cacert.pem" and other lines are related to mail server restarted, etc.
OPENSSL versions?
only one or while ... maybe more.?
I can't help but such things could be important for those who can. :eek:
Also you didn't stil mentioned wich SSL issue??
OpenSSL is ok. I think this is related to permission. Unfortunately I can't see LetsEncrypt logs like If permission was denied or something else however I managed to fix it by manually copying it from domains/ssl certs to conf directory and now SSL is working. ;)
I will fix it later.
Same problem here - how to fix it? Let's encrypt doesn't create files in /usr/local/directadmin/conf/
CentOS 7.8
DA - newest
Will
/usr/local/directadmin/scripts/set_permissions.sh da_files
fix the issue and allow installation of certificates into DirectAdmin?
If it does not help then please show
ls -la /usr/local/directadmin/conf/
ls -dla /usr/local/directadmin/conf/
Still nothing.... @zEitEr ;/
razem 36
drwx------ 2 diradmin diradmin 4096 12-16 14:55 .
drwxr-xr-x 7 diradmin diradmin 4096 12-18 17:30 ..
-rw------- 1 diradmin diradmin 2238 12-14 14:33 directadmin.conf
-rw------- 1 diradmin diradmin 3243 12-06 00:12 letsencrypt.key
-rw------- 1 diradmin diradmin 1430 12-06 00:12 letsencrypt.key.json
-rw------- 1 diradmin diradmin 1559 12-16 14:55 license.key
-rw------- 1 diradmin diradmin 1559 11-30 04:01 license.old
-rw------- 1 diradmin diradmin   50 11-17 20:59 my.cnf
-rw------- 1 diradmin diradmin   39 11-17 20:59 mysql.conf
drwx------ 2 diradmin diradmin 4096 12-16 14:55 /usr/local/directadmin/conf/
Really guys? No one can help me? I still have this problem... and I can't because of this connect throught SSL in DA :///
Please follow https://help.directadmin.com/item.php?id=629 to enable SSL for DirectAdmin.
I did everything I found on the internet... this is new dedicated server, on other my servers everything is working fine....
I generated couple of time successfully this stupid certificate - I can go to this page throught SSL (without :2222 port)
I did also "set_permissions" etc. nothing is working... it's not creating in /usr/local/directadmin/conf/ I don't know why if permissions are set fine??
It should show some errors if it fails, please post them.
Where should I check this errors? in /var/log/directadmin there's nothing in logs...? let's encrypt generates fine this certificate... no errors... but it doesn't move them to directadmin's dir...
