- Feb 27, 2003
We're pleased to announce DirectAdmin 1.61.1.
This is primarily a bug-fix release, but there are some fun new features added.
All changes are listed in the versions system:
https://www.directadmin.com/versions.php?version=1.611000
New Features:
To update, go to your Admin Level » Licenses/Updates.
Let us know if you have any issues.
New Features:
- Internal Translations using gettext (.po files) [GUIDE]
- User daily send limit available as package options
- dnssec keygen options for algorithm and bitsize
- FileManager: extract specific file/files from within a zip/tar.gz
- Option to hide NS/PTR records
- Restore not including certificates/pointers
- removeip script to use absolute path to '/sbin/ip'
- Lost Password Reset (SECURITY)
- startips: not reading addip script correctly
- Log Viewer showing raw headers after log output
- Database Access Hosts: now allows wildcard mid-host
- Do not allow duplicate custom package item that duplicates a standard user.conf item
- Leftover non_readable_files folder after User backup
- Cleanup left-over tar.gz/zip from 'compress and download' if there is a timeout or other signal/error.
- Global IP: auto convert owner to an Admin if it was owned by a Reseller.
- fm_purge_trash_days not loaded in
- php_home_tmp_esssion_save_path incorrectly reverted to default 0 Now reset to 1 where applicable.
- SDOCROOT needed in <Directory> contents for subdomains
- Respect intentional pre-existing out-of-range values when saving email password
- Restore multiple files from FileManager Trash
