DirectAdmin v1.63.1 RC
fln
Administrator
Staff member
Hi everyone!
We're happy to announce the release candidate for 1.63.1.
This version includes a series of bug-fixes and a couple of improvements, change-log can be found here:
DirectAdmin 1.63.1
The update should be automatically available for all installations subscribed to the beta release channel.
fln
Hi!
This is a good one "Add CLI for backuping" , but I think needs to be complemented with the restore function.
Regards
@dmtinc, yes restore function is still available either via web interface or manually via custom dataskq job. With this feature we are targeting use cases when data needs to be migrated out of old DA installation that no longer has a valid license and web interface is non functional. Something described in this help article.
On functional DA installations restore via web interface is preferred method. Do you have a use case for restoring using only CLI?
The new installer has bug. both nginx and httpd reported error (using nginx_apache):
# nginx:
● nginx.service - The nginx HTTP and reverse proxy server
     Loaded: loaded (/etc/systemd/system/nginx.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Mon 2021-11-08 23:48:56 +08; 45min ago
        CPU: 369ms
Nov 09 00:01:15 - systemd[1]: /etc/systemd/system/nginx.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Nov 09 00:01:16 - systemd[1]: /etc/systemd/system/nginx.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Nov 09 00:01:40 - systemd[1]: /etc/systemd/system/nginx.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Nov 09 00:02:52 - systemd[1]: /etc/systemd/system/nginx.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Nov 09 00:02:53 - systemd[1]: /etc/systemd/system/nginx.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Nov 09 00:03:05 - systemd[1]: /etc/systemd/system/nginx.service:11: PIDFile= references a path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
# httpd
● httpd.service - The Apache HTTP Server
     Loaded: loaded (/etc/systemd/system/httpd.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Mon 2021-11-08 23:48:55 +08; 49min ago
   Main PID: 455136 (code=exited, status=1/FAILURE)
        CPU: 22ms
Nov 08 23:48:55 - systemd[1]: Starting The Apache HTTP Server...
Nov 08 23:48:55 - httpd[455136]: httpd: Syntax error on line 224 of /etc/httpd/conf/httpd.conf: Syntax error on line 23 of /etc/httpd/conf/extra/httpd-vhosts.conf: Could not open configuration file /etc/httpd/conf/ips.conf: No such file or directory
Nov 08 23:48:55 - systemd[1]: httpd.service: Main process exited, code=exited, status=1/FAILURE
Nov 08 23:48:55 - systemd[1]: httpd.service: Failed with result 'exit-code'.
Nov 08 23:48:55 - systemd[1]: Failed to start The Apache HTTP Server.
and this happened before in 2020 post: https://forum.directadmin.com/threads/install-da-with-single-bash-script.61746/post-318651
This is the content of my ips.conf that the httpd complains it is missing is this:
# Auto generated apache config file by DirectAdmin version 1.63.1
# Modifying this file is not recommended as any changes you make will be
# overwritten when you add/remove ip's through DirectAdmin.
LogFormat "%O \"%r\"" homedir
The installer completed with no error, just that nginx and apache won't start. How can I debug this?
We have released a hot-fix for the beta and current release channels. Latest build with the fix is a7632e8d7e8d18200955896464b242c5df79f109.
The problem was caused by license handling changes in the dataskq binary. @kalibzen could you please try running the installation again?
