Active8
- Jul 13, 2013
Hi @fln , did you update CB because its failing again ....
Updating cURL
Removing file: /usr/local/share/man/man1/curl-config.1...
Removing file: /usr/local/share/man/man1/curl.1...
Removing file: /usr/local/bin/curl...
Removing file: /usr/local/bin/curl-config...
Removing directory: /usr/local/include/curl...
Removing file: /usr/local/share/aclocal/libcurl.m4...
Rebuilding PHP to make sure it does not depend on compiled version of cURL
./build: line 1206: /usr/local/bin/curl: No such file or directory
Download of https://files.directadmin.com/services/custombuild/php-7.4.33.tar.gz failed, re-downloading the file...
Download of https://files.directadmin.com/services/custombuild/php-7.4.33.tar.gz failed 4 times, exiting...
I can download that php file using wget command so there is no really an connection issue...
Updating cURL
