netswitch said:What do I have to do to have this kind of email directly deleted by MailScanner ?
Option should be in mailscanner.conf
Chris
pilpelet said:Hello to all ,
I tried all the configs , i prety sure i installed it ok . its atrting stopping ok , no errors but the scanner itself simply dont scan .
I playd with all the configs and took every suggestunes posted here . simply nada .
Any idea will be great .
i have the same problem;Watje6 said:Hello,
When a mail is sent by webmail it adds the header that the email is scanned by mailscanner, but when a mail is sent from another server to an mailbox on our server it doesn't scan the email (also doesn't add the header lines).
Anybody knows where to find our prob ?
YouCMe said:i have the same problem;
Mails sended by webforms or admin information mails from DirectAdmin get the headers (and the {Scanned} tag) but the mails i send from within MS Outlook don't get the headers. Anyone knows a for this solution?
blueice said:Hi,
so finaly have any right install of this in freebsd box?
Config attached*Icheb said:Stupid question: are you using the servers (that's in question) smtp server or own ISP ?
Further questions :
Can you post/attach your mailscanner config ?
Are both the exim's running good ?
(Didn't you reverse them or something, strange things happen when you reverse them)
--------------------------------------------------------------------------------Icheb said:Stupid question: are you using the servers (that's in question) smtp server or own ISP ?
Further questions :
