"/etc/my.cnf" E212: Can't open file for writing
040810 20:36:00 mysqld started
040810 20:36:00 Can't start server : Bind on unix socket: No such file or directory
040810 20:36:00 Do you already have another mysqld server running on socket: /var/lib/mysql/mysql.sock ?
040810 20:36:00 Aborting
040810 20:36:00 /usr/local/mysql-4.0.17-unknown-freebsd5.1-i386/bin/mysqld: Shutdown Complete
040810 20:36:00 mysqld ended
[mysqld]
#datadir=/var/lib/mysql
#socket=/var/lib/mysql/mysql.sock
skip-locking
skip-innodb
query_cache_limit=1M
query_cache_size=32M
query_cache_type=1
max_connections=500
interactive_timeout=100
wait_timeout=100
connect_timeout=10
thread_cache_size=128
key_buffer=16M
join_buffer=1M
max_allowed_packet=16M
table_cache=1024
record_buffer=1M
sort_buffer_size=2M
read_buffer_size=2M
max_connect_errors=10
# Try number of CPU's*2 for thread_concurrency
thread_concurrency=2
myisam_sort_buffer_size=64M
log-bin
server-id=1
| Variable_name | Value |
| Qcache_queries_in_cache | 47 |
| Qcache_inserts | 56 |
| Qcache_hits | 133 |
| Qcache_lowmem_prunes | 0 |
| Qcache_not_cached | 10 |
| Qcache_free_memory | 16708008 |
| Qcache_free_blocks | 4 |
| Qcache_total_blocks | 110 |
back_log 50
basedir /
binlog_cache_size 32768
bulk_insert_buffer_size 8388608
character_set latin1
character_sets latin1 big5 czech euc_kr gb2312 gbk latin1_de sjis...
concurrent_insert ON
connect_timeout 10
convert_character_set
datadir /var/lib/mysql/
default_week_format 0
delay_key_write ON
delayed_insert_limit 100
delayed_insert_timeout 300
delayed_queue_size 1000
flush OFF
flush_time 0
ft_boolean_syntax + -><()~*:""&|
ft_min_word_len 4
ft_max_word_len 254
ft_max_word_len_for_sort 20
ft_stopword_file (built-in)
have_bdb NO
have_crypt YES
have_innodb DISABLED
have_isam YES
have_raid NO
have_symlink YES
have_openssl NO
have_query_cache YES
init_file
innodb_additional_mem_pool_size 1048576
innodb_buffer_pool_size 8388608
innodb_data_file_path
innodb_data_home_dir
innodb_file_io_threads 4
innodb_force_recovery 0
innodb_thread_concurrency 8
innodb_flush_log_at_trx_commit 1
innodb_fast_shutdown ON
innodb_flush_method
innodb_lock_wait_timeout 50
innodb_log_arch_dir
innodb_log_archive OFF
innodb_log_buffer_size 1048576
innodb_log_file_size 5242880
innodb_log_files_in_group 2
innodb_log_group_home_dir
innodb_mirrored_log_groups 1
innodb_max_dirty_pages_pct 90
interactive_timeout 100
join_buffer_size 1044480
key_buffer_size 289406976
language /usr/share/mysql/english/
large_files_support ON
license GPL
local_infile ON
locked_in_memory OFF
log OFF
log_update OFF
log_bin ON
log_slave_updates OFF
log_slow_queries OFF
log_warnings ON
long_query_time 10
low_priority_updates OFF
lower_case_file_system OFF
lower_case_table_names 0
max_allowed_packet 16776192
max_binlog_cache_size 4294967295
max_binlog_size 1073741824
max_connections 500
max_connect_errors 10
max_delayed_threads 20
max_insert_delayed_threads 20
max_heap_table_size 16777216
max_join_size 4294967295
max_relay_log_size 0
max_seeks_for_key 4294967295
max_sort_length 1024
max_user_connections 0
max_tmp_tables 32
max_write_lock_count 4294967295
myisam_max_extra_sort_file_size 268435456
myisam_max_sort_file_size 2147483647
myisam_repair_threads 1
myisam_recover_options OFF
myisam_sort_buffer_size 75497472
net_buffer_length 16384
net_read_timeout 30
net_retry_count 10
net_write_timeout 60
new OFF
open_files_limit 4096
pid_file /var/lib/mysql/server.Innerearaudio.com.pid
log_error
port 3306
protocol_version 10
query_alloc_block_size 8192
query_cache_limit 1048576
Variable_name Value
query_cache_size 16777216
query_cache_type ON
query_prealloc_size 8192
range_alloc_block_size 2048
read_buffer_size 10481664
read_only OFF
read_rnd_buffer_size 262144
rpl_recovery_rank 0
server_id 1
slave_net_timeout 3600
skip_external_locking ON
skip_networking OFF
skip_show_database OFF
slow_launch_time 2
socket /var/lib/mysql/mysql.sock
sort_buffer_size 1048568
sql_mode 0
table_cache 1024
table_type MYISAM
thread_cache_size 128
thread_stack 126976
tx_isolation REPEATABLE-READ
timezone EDT
tmp_table_size 33554432
tmpdir /tmp/
transaction_alloc_block_size 8192
transaction_prealloc_size 4096
version 4.0.20-standard-log
version_comment Official MySQL RPM
version_compile_os pc-linux
wait_timeout 100
max_connections = 500
wait_timeout=100
connect_timeout=10
skip-innodb
skip-locking
query_cache_size=16M
query_cache_type=1
key_buffer=276M
join_buffer=1M
table_cache=1024
sort_buffer_size=1M
record_buffer=16M
read_buffer_size=10M
myisam_sort_buffer_size=72M
[mysqldump]
quick
[mysql]
no-auto-rehash
# Remove the next comment character if you are not familiar with SQL
#safe-updates
[isamchk]
key_buffer=268M
read_buffer=1M
write_buffer=1M
[myisamchk]
key_buffer=268M
read_buffer=1M
write_buffer=1M
[mysqlhotcopy]
interactive-timeout
Parse Time: 0.195s
Try:Thafusion said:hercules# /etc/rc.d/init.d/mysqld restart
/etc/rc.d/init.d/mysqld: Command not found.
And when i put any config in my my.cnf then mysql don't restart when i do a reboot . Also in the directadmin panel i can't use the start thing. Any help ?
/etc/rc.d/init.d/mysql restart
lnguyen said:when trying to run this:
mysqlcheck -o -u root -p --all-databases
from that ev1 thread, my root password is not accepted, it says root@localhost has been denied.
Any ideas?
