I was going to reinstall DA and I removed the setup.txt and ran the install.sh and found it only work for FreeBSD 4.8. I thought you might want to look into that.
? install.sh assumes that the setup.txt already exists.. if it does it might go into the really old way of getting the data, which probably won't work.. try creating the setup.txt first, (with setup.sh) .. then try again.
