Hello Andrea,
Kindly clarify what you mean. Do you want to say that you customized exim.pl on one of your server and it was overwritten with a default exim.pl? If so, then it's normal behavior unless you has an option not to update exim.conf/exim.pl with Custombuild.
If you want to have exim.conf of a latest version and exim.pl with your modifications, then you might consider using chattr and set the file immutable.
