Unable to login to admin panel | Fresh DA Installation
Look at the user account level setting, ensure that the PHP option is ticked to enable it
Do user/reseller have PHP setting enabled in their package/settings too? Are you sure that version of PHP is compiled? If not:
./build php n
./build php n
yes php is enabled to reseller/user.
i have recompiled php as well, but it didn't resolved the issue.
Copying php.ini..
/usr/local/lib/php.ini already exists, skipping.
Enabling mail.add_x_header option in /usr/local/lib/php.ini
PHP 7.2.20 Installed.
Apache 2.4.27 and higher will not negotiate http2 with mpm_prefork. Please do no t use mod_php or disable http2 in the directadmin.conf
http://www.apache.org/dist/httpd/CHANGES_2.4.27
Rewriting all users httpd.conf files, please wait...
Debug mode. Level 10
dataskq: command: action=rewrite&value=httpd
Restarting apache.
I'd suggest creating a ticket at tickets.directadmin.com with access details and website name. It'd be checked asap, and you'd know the root cause of the problem :) Thank you!
