HTTPd fails from 2.4.39 to 2.4.41 update
If you're on non-CL, are you running CentOS <7.4? APR might be selecting getrandom syscall even when it shouldn't:
RHEL 7.4 introduces the getrandom() system call, which combines the best of the existing interfaces
Another guess - OpenVZ kernel has this issue, as CL relies on them too as far as I remember :)
Anyone with this issue on native CentOS kernel or Debian/FreeBSD? I guess none, but I'd like to be sure.
I'm on 7.6, and OpenVZ6, see below:
[root@cluster custombuild]# cat /etc/redhat-release
CentOS Linux release 7.6.1810 (Core)
[root@cluster custombuild]# uname -a
Linux cluster.ikwright.com 2.6.32-042stab139.1 #1 SMP Tue Jun 18 12:51:14 MSK 2019 x86_64 x86_64 x86_64 GNU/Linux
No reported issues on our OpenVZ7 instances, yet.
Quick fix for now:
ln -sf /usr/lib/apache/libapr-1.so.0.6.5 /usr/lib/apache/libapr-1.so.0
Continuing to investigate.
[root@s01 custombuild]# ln -sf /usr/lib/apache/libapr-1.so.0.6.5 /usr/lib/apache/libapr-1.so.0
[root@s01 custombuild]# httpd -v
httpd: symbol lookup error: httpd: undefined symbol: apr_atomic_read64
Any idea?
We're seeing this too. 6 machines so far this morning. Let me know if you need more cases to check against.
We do have a couple hundreds of server with OVZ6+CentOS+DA. The issue is happening with the most recent servers with auto update enabled.
At some of them, the following worked (I believe that it just works if you do the following before: cd /usr/local/directadmin/custombuild ; ./build update ; ./build apache ; ./build php n ; ./build rewrite_confs):
ln -sf /usr/lib/apache/libapr-1.so.0.6.5 /usr/lib/apache/libapr-1.so.0 ; service httpd restart
At the ones that the ln has not fixed, we are receiving:
# httpd -V
I am trying to build apache to confirm
Quick fix for now:
rm -f /usr/lib/apache/libapr-1.so.0.7.0 /usr/lib/apache/libapr-1.so.0
perl -pi -e 's|apr:1.7.0:757239852b082b844e268a86f2806fd2|apr:1.6.5:|g' versions.txt
./build apache
Offtopic: Is there any reason why on FreeBSD in versions.txt I read "apr:1.6.5" but with httpd -V I get:
Server loaded: APR 1.7.0, APR-UTIL 1.6.1
Compiled using: APR 1.7.0, APR-UTIL 1.6.1
It looks like Custombuild is building against APR 1.7.0 regardless of what is written in versions.txt. And I am unsure why 1.6.5 is listed in versions.txt but not the latest version.
Is that a temporarily fix (downgrading APR) for people with issues which is skipped for FreeBSD through the build script?
I'm on Centos 7.6.1810 64-bit and had the same error. The quick fix suggested by smtalk worked for me.
Please keep me posted if anything else should be fixed when this problem is solved.
no issues
KVM - Cloud Linux 7 3.10 kernel (not hybrid 4 which is beta) converted from 7.6.1810 Centos iso
httpd -V
Server version: Apache/2.4.41 (Unix)
Server built:   Aug 15 2019 09:19:40
Server's Module Magic Number: 20120211:88
LXC Centos 7 - 5.0 kernel (Proxmox 6) from Proxmox template, updated with yum prior to DirectAdmin install and then yum cron
httpd -V
Server built:   Aug 15 2019 08:50:37
Both have epel-repo enabled
Same issue on VPS
I have an OpenVZ VPS and am seeing the same error, but it gets stranger...
I've made and installed and get this:
[root@server15 httpd-2.4.41]# /usr/local/apache2/bin/httpd -v
[Mon Aug 19 12:43:26.424750 2019] [:crit] [pid 5064] (38)Function not implemented: AH00141: Could not initialize random number generator
but the local build I get this:
[root@server15 httpd-2.4.41]# ./httpd -v
Server built: Aug 19 2019 12:39:25
copy httpd and all the other files
[root@server15 httpd-2.4.41]# cp httpd* /usr/local/apache2/bin/
cp: overwrite '/usr/local/apache2/bin/httpd'? y
Server version: Apache/2.4.39 (Unix)
Server built: Jul 12 2019 16:38:15
I've even deleted, confirmed deleted, recopied, still says 2.4.39 when I run /usr/local/apache2/bin/httpd folder version of the binary...
The dates on the file system are the old file 2.4.39 dates.... I really don't understand it or why its not copying or not appearing to copy or what.?!
Anyone any idea? The only thing I can put it down to is a file system error, but it is really really odd!
Can you share the command to upgrade the httpd version from 2.4.6 to 2.4.41
Unfortunately, downgrading does not fix it.
I'm on a CentOS7 64 bit image, and even installing fresh causes the following issue with Apache/HTTPD:
[Thu Aug 15 05:26:14.994352 2019] [:crit] [pid 15388] (38)Function not implemented: AH00141: Could not initialize random number generator
No errors located in apache's error log, either.
Anyone else having this issue, or know of a fix?
@Hemanth: Here you go:
./build apache
I need direct linux commands to upgrade this from 2.4.6 to 2.4.41
Those are "direct linux commands" to upgrade from 2.4.6 to 2.4.41.
There is no folder with this name "directadmin" under /etc/local.
Can you guide me with exact steps how to download this folder or how to get this folder?
