Benchmark Run: Sat Feb 20 2010 17:10:05 - 17:38:28
8 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables 9415911.4 lps (10.0 s, 7 samples)
Double-Precision Whetstone 2095.3 MWIPS (10.2 s, 7 samples)
Execl Throughput 2712.2 lps (29.8 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks 265152.0 KBps (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks 71215.5 KBps (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks 639312.0 KBps (30.1 s, 2 samples)
Pipe Throughput 427862.7 lps (10.0 s, 7 samples)
Pipe-based Context Switching 101300.5 lps (10.0 s, 7 samples)
Process Creation 9379.1 lps (30.0 s, 2 samples)
Shell Scripts (1 concurrent) 5250.9 lpm (60.0 s, 2 samples)
Shell Scripts (8 concurrent) 2354.9 lpm (60.0 s, 2 samples)
System Call Overhead 801013.5 lps (10.0 s, 7 samples)
System Benchmarks Index Values BASELINE RESULT INDEX
Dhrystone 2 using register variables 116700.0 9415911.4 806.8
Double-Precision Whetstone 55.0 2095.3 381.0
Execl Throughput 43.0 2712.2 630.7
File Copy 1024 bufsize 2000 maxblocks 3960.0 265152.0 669.6
File Copy 256 bufsize 500 maxblocks 1655.0 71215.5 430.3
File Copy 4096 bufsize 8000 maxblocks 5800.0 639312.0 1102.3
Pipe Throughput 12440.0 427862.7 343.9
Pipe-based Context Switching 4000.0 101300.5 253.3
Process Creation 126.0 9379.1 744.4
Shell Scripts (1 concurrent) 42.4 5250.9 1238.4
Shell Scripts (8 concurrent) 6.0 2354.9 3924.8
System Call Overhead 15000.0 801013.5 534.0
System Benchmarks Index Score 683.3
Benchmark Run: Sat Feb 20 2010 17:38:28 - 18:06:47
8 CPUs in system; running 8 parallel copies of tests
Dhrystone 2 using register variables 75673460.7 lps (10.0 s, 7 samples)
Double-Precision Whetstone 16835.6 MWIPS (10.2 s, 7 samples)
Execl Throughput 17436.3 lps (29.7 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks 160879.7 KBps (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks 42444.9 KBps (30.1 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks 520439.1 KBps (30.0 s, 2 samples)
Pipe Throughput 3447694.2 lps (10.0 s, 7 samples)
Pipe-based Context Switching 1317252.0 lps (10.0 s, 7 samples)
Process Creation 57007.2 lps (30.0 s, 2 samples)
Shell Scripts (1 concurrent) 26366.2 lpm (60.1 s, 2 samples)
Shell Scripts (8 concurrent) 3633.8 lpm (60.0 s, 2 samples)
System Call Overhead 1794966.3 lps (10.0 s, 7 samples)
Dhrystone 2 using register variables 116700.0 75673460.7 6484.4
Double-Precision Whetstone 55.0 16835.6 3061.0
Execl Throughput 43.0 17436.3 4055.0
File Copy 1024 bufsize 2000 maxblocks 3960.0 160879.7 406.3
File Copy 256 bufsize 500 maxblocks 1655.0 42444.9 256.5
File Copy 4096 bufsize 8000 maxblocks 5800.0 520439.1 897.3
Pipe Throughput 12440.0 3447694.2 2771.5
Pipe-based Context Switching 4000.0 1317252.0 3293.1
Process Creation 126.0 57007.2 4524.4
Shell Scripts (1 concurrent) 42.4 26366.2 6218.4
Shell Scripts (8 concurrent) 6.0 3633.8 6056.3
System Call Overhead 15000.0 1794966.3 1196.6
System Benchmarks Index Score 2215.7
