Changing the backup directory path in "Admin Backups >> Restore Backup" changes the local_path in backup.conf
If you attempt to restore from this directory (not owned by admin) no error message is generated; it simply fails to load the files.
If you go to schedule a backup in Admin Backups >> Scheule Backups the backup path has changed to match backup.conf.
If you try to run a backup, you will get this error:
Can an error message be added to the restore page if directory not owned by admin is chosen?
[root@host ~]# cat /usr/local/directadmin/data/admin/backup.conf
append_to_path=nothing
ftp_ip=
ftp_password=
ftp_path=/
ftp_port=21
ftp_secure=no
ftp_username=
local_path=/root/backup
Backup path /root/backup has been created.
Path /root/backup does not exist or is not accessible by the admin user.
Permission denied.
