Apache problems please help asap
niels
Please can someone help me asap,
Because I have tried several days to fix it but I can't fix it.
I think it's apache because if i want to restart apache it works 3 seconds than he will stop.
If i put on the link Reload he will stop, and not reload.
I cann't reach my sites on their domains.
I get an error that the host can't find.
Who can help me?
thanks in advance
Niels
Are you getting any error message in /var/log/messages/
Any other information? Perhaps you could have someone from here log in and take a look...
I see this on the first line in my error.log
Unable to read config file. Check to make sure that /usr/local/directadmin/conf/directadmin.conf.lock doesn't exist
and this on the last lines
2004:03:24-12:50:34: Socket write error: Unknown error
2004:03:24-12:50:34: Error while sending ./data/skins/default/images/pix.gif
is see this in the file
/var/log/directadmin/error.log
maybe someone want look for it
thanks in advance
Niels
No, it has stil run 2 months,
But the last time I get more troubles with it.
Please if there is one of the makers of DA and can help me.
I'll give you the codes to look in my server.
Check to make sure that /usr/local/directadmin/conf/directadmin.conf exists and is readable by the "diradmin" user. Also check for things like your hard drive being full. Failing that, you can send an email to [email protected] with your ip and root pass, or else use https://www.directadmin.com/clients/safesubmit.php
The error you've pasted doesn't really have anything to do with apache.. you'd want to check /var/log/httpd/error_log if apache isn't working.
