Hello
I'm new on DA, playing around with one test account on a server.
If I want to create a autoresponder I get this:
On the Server I see that the file indeed not exists:
This is a fresh install of the current version. Whats wrong with it?
The mailsystem seams broken in general (can't safe sent mails, spamd cant't start, no autoconfig)
Any idea?
I've installed the box with the DA setup guide
Error writing /etc/virtual/balbal.xyz/reply/sds.headers : Cannot stat the source file: /usr/local/directadmin/data/templates/reply_headers.txt
[root@da-dev1 ~]# ls /usr/local/directadmin/data/templates/
apache.logrotate dns_cname.conf filter_base logs.list nginx_server.conf php-fpm.conf user_suspension.txt
block_cracking_notice_denied_path.txt dns_mx.conf filter_delete lost_password_email.txt nginx_server_redirect.conf proftpd.conf user_virtual_host.conf
block_cracking_notice_script.txt dns_ns.conf filter_filterspamfolder lost_password.html nginx_server_secure.conf proftpd.vhosts.conf virtual_host2.conf
block_cracking_notice.txt dns_spf.conf filter_spamfolder mail_settings.html nginx_server_secure_sub.conf README virtual_host2_secure.conf
brute_filter.list dns_srv.conf filter_userspamfolder main.php nginx_server_sub.conf redirect_virtual_host.conf virtual_host2_secure_sub.conf
config.inc.php dns_tlsa.conf forbidden_domains.list majordomo.cf openlitespeed_context_protected.conf reply_content-types.list virtual_host2_sub.conf
config.inc.php.backup dns_txt.conf ftp_pass_change message_footer.txt openlitespeed_ips.conf reply_encodings.list virtual_host.conf
conf.sysbk dovecot_sni.conf httpd message_tech.txt openlitespeed_listener.conf reseller_limit.txt virtual_host_secure.conf
custom edit_files.txt httpd.conf message_user.txt openlitespeed_redirect_vhost.conf rspamd_settings.conf virtual_host_secure_sub.conf
da-popb4smtp email_limit_message.txt imap mx openlitespeed_vhost.conf suspended virtual_host_sub.conf
default email_pass_change imaps named.db outlook_setup.reg suspension_reason.txt zone.conf
directadmin.conf exim3.conf ips_virtual_host.conf nginx_ips.conf partition_check.list system_filter.exim
dns_aaaa.conf exim4.conf list.config nginx_php.conf partition_check_message.txt userdir
dns_a.conf exim.conf load_check_message.txt nginx_protected_directory.conf per_email_limit_email_message.txt user_limit.txt
dns_caa.conf exim.pl login_images nginx_redirect.conf per_email_limit_message.txt user_prefs
Any idea?
