LIBJPEG
- Executing /usr/local/directadmin/plugins/custombuild/admin/build libjpeg...
- Downloading jpegsrc.v9d.tar.gz...
- --2020-07-27 09:30:07-- https://files2.directadmin.com/services/custombuild/jpegsrc.v9d.tar.gz
- Resolving files2.directadmin.com (files2.directadmin.com)... 185.42.221.168
- Connecting to files2.directadmin.com (files2.directadmin.com)|185.42.221.168|:443... connected.
- HTTP request sent, awaiting response... 200 OK
- Length: 1070160 (1.0M) [application/x-gzip]
- Saving to: '/usr/local/directadmin/custombuild/jpegsrc.v9d.tar.gz'
- 0K .......... .......... .......... .......... .......... 4% 40.8M 0s
- 50K .......... .......... .......... .......... .......... 9% 82.1M 0s
- 100K .......... .......... .......... .......... .......... 14% 65.7M 0s
- 150K .......... .......... .......... .......... .......... 19% 59.3M 0s
- 200K .......... .......... .......... .......... .......... 23% 81.7M 0s
- 250K .......... .......... .......... .......... .......... 28% 63.6M 0s
- 300K .......... .......... .......... .......... .......... 33% 67.5M 0s
- 350K .......... .......... .......... .......... .......... 38% 61.1M 0s
- 400K .......... .......... .......... .......... .......... 43% 59.2M 0s
- 450K .......... .......... .......... .......... .......... 47% 68.3M 0s
- 500K .......... .......... .......... .......... .......... 52% 67.6M 0s
- 550K .......... .......... .......... .......... .......... 57% 80.0M 0s
- 600K .......... .......... .......... .......... .......... 62% 87.2M 0s
- 650K .......... .......... .......... .......... .......... 66% 75.2M 0s
- 700K .......... .......... .......... .......... .......... 71% 67.6M 0s
- 750K .......... .......... .......... .......... .......... 76% 89.1M 0s
- 800K .......... .......... .......... .......... .......... 81% 85.8M 0s
- 850K .......... .......... .......... .......... .......... 86% 83.0M 0s
- 900K .......... .......... .......... .......... .......... 90% 63.2M 0s
- 950K .......... .......... .......... .......... .......... 95% 130M 0s
- 1000K .......... .......... .......... .......... ..... 100% 101M=0.01s
- 2020-07-27 09:30:07 (71.2 MB/s) - '/usr/local/directadmin/custombuild/jpegsrc.v9d.tar.gz' saved [1070160/1070160]
- checking build system type... x86_64-pc-linux-gnu
- checking host system type... x86_64-pc-linux-gnu
- checking target system type... x86_64-pc-linux-gnu
- checking for a BSD-compatible install... /bin/install -c
- checking whether build environment is sane... yes
- checking for a thread-safe mkdir -p... /bin/mkdir -p
- checking for gawk... gawk
- checking whether make sets $(MAKE)... yes
- checking whether make supports nested variables... yes
- checking whether make supports nested variables... (cached) yes
- checking whether to enable maintainer-specific portions of Makefiles... no
- checking for gcc... gcc
- checking whether the C compiler works... no
- configure: error: in `/usr/local/directadmin/custombuild/jpeg-9d':
- configure: error: C compiler cannot create executables
- See `config.log' for more details
- Trying to make libjpeg...
- make: *** No targets specified and no makefile found. Stop.
- Done!
- Executing /usr/local/directadmin/plugins/custombuild/admin/build exim...
- Found /usr/local/directadmin/custombuild/exim-4.94.tar.gz
- Extracting ...
- Done.
- Downloading exim-4.94/Local/Makefile...
- --2020-07-27 09:30:47-- https://files2.directadmin.com/services/custombuild/Makefile
- Length: 48603 (47K)
- Saving to: '/usr/local/directadmin/custombuild/exim-4.94/Local/Makefile'
- 0K .......... .......... .......... .......... ....... 100% 38.4M=0.001s
- 2020-07-27 09:30:47 (38.4 MB/s) - '/usr/local/directadmin/custombuild/exim-4.94/Local/Makefile' saved [48603/48603]
- Making Makefile changes for 4.93+
- Trying to make exim...
- /bin/sh scripts/source_checks
- >>> Creating links to source files...
- >>> Creating lookups/Makefile for building dynamic modules
- >>> New Makefile & lookups/Makefile installed
- >>> Use "make makefile" if you need to force rebuilding of the makefile
- make[1]: warning: -jN forced in submake: disabling jobserver mode.
- make[1]: Entering directory '/usr/local/directadmin/custombuild/exim-4.94/build-Linux-x86_64'
- /bin/sh ../scripts/Configure-os.c
- cc buildconfig.c
- /bin/sh ../scripts/Configure-os.h
- cc exim_lock.c
- as: error while loading shared libraries: /usr/lib64/libopcodes-2.30-73.el8.so: file too short
- make[1]: *** [Makefile:707: exim_lock] Error 1
- make[1]: *** Waiting for unfinished jobs....
- make[1]: *** [Makefile:381: buildconfig] Error 1
- make[1]: Leaving directory '/usr/local/directadmin/custombuild/exim-4.94/build-Linux-x86_64'
- make: *** [Makefile:35: all] Error 2
- Done!
- Executing /usr/local/directadmin/plugins/custombuild/admin/build exim_conf...
- Downgrading exim configuration version to 4.5.23 as the newest one requires exim 4.94 or newer.
- --2020-07-27 09:31:06-- https://files2.directadmin.com/serv...3/exim.conf-SpamBlockerTechnology-v4.5.23.txt
- Length: 34845 (34K) [text/plain]
- Saving to: '/etc/exim.conf.cb20'
- 0K .......... .......... .......... .... 100% 45.0M=0.001s
- 2020-07-27 09:31:06 (45.0 MB/s) - '/etc/exim.conf.cb20' saved [34845/34845]
- --2020-07-27 09:31:06-- https://files2.directadmin.com/services/custombuild/system_filter.exim
- Length: 10495 (10K)
- Saving to: '/etc/system_filter.exim'
- 0K .......... 100% 52.6M=0s
- 2020-07-27 09:31:06 (52.6 MB/s) - '/etc/system_filter.exim' saved [10495/10495]
- --2020-07-27 09:31:06-- https://files2.directadmin.com/services/SpamBlocker/4.5.23/exim.strings.conf
- Length: 2076 (2.0K) [text/plain]
- Saving to: '/etc/exim.strings.conf.cb20'
- 0K .. 100% 138M=0s
- 2020-07-27 09:31:06 (138 MB/s) - '/etc/exim.strings.conf.cb20' saved [2076/2076]
- --2020-07-27 09:31:06-- https://files2.directadmin.com/services/SpamBlocker/4.5.23/exim.variables.conf.default
- Length: 996 [text/plain]
- Saving to: '/etc/exim.variables.conf.cb20'
- 0K 100% 43.6M=0s
- 2020-07-27 09:31:06 (43.6 MB/s) - '/etc/exim.variables.conf.cb20' saved [996/996]
- --2020-07-27 09:31:07-- https://files2.directadmin.com/services/exim.pl.29
- Length: 18976 (19K)
- Saving to: '/etc/exim.pl.cb20'
- 0K .......... ........ 100% 32.0M=0.001s
- 2020-07-27 09:31:07 (32.0 MB/s) - '/etc/exim.pl.cb20' saved [18976/18976]
- Restarting exim.
- Done!
- Executing /usr/local/directadmin/plugins/custombuild/admin/build php_expert 7.2 php-fpm...
- ldconfig: File /lib64/libbfd-2.30-73.el8.so is empty, not checked.
- ldconfig: File /lib64/libopcodes-2.30-73.el8.so is empty, not checked.
- Found /usr/local/directadmin/custombuild/php-7.2.32.tar.gz
- Extracting ...
- Done.
- Configuring php-7.2.32...
- Patching php-fpm to not fail on startup if User quota maxed out on socket chown
- patching file sapi/fpm/fpm/fpm_unix.c
- checking for grep that handles long lines and -e... /bin/grep
- checking for egrep... /bin/grep -E
- checking for a sed that does not truncate output... /bin/sed
- checking build system type... x86_64-unknown-linux-gnu
- checking host system type... x86_64-unknown-linux-gnu
- checking target system type... x86_64-unknown-linux-gnu
- shtool:echo:Warning: unable to determine terminal sequence for bold mode
- checking for cc... cc
- configure: error: in `/usr/local/directadmin/custombuild/php-7.2.32':
- *** There was an error while trying to configure php. Check the configure file
- Done!
- Executing /usr/local/directadmin/plugins/custombuild/admin/build php_expert 7.3 php-fpm...
- Found /usr/local/directadmin/custombuild/php-7.3.20.tar.gz
- Extracting ...
- Done.
- Configuring php-7.3.20...
- patching file ext/mysqlnd/mysqlnd_auth.c
- Hunk #6 succeeded at 610 (offset 3 lines).
- Hunk #7 succeeded at 660 (offset 3 lines).
- Hunk #8 succeeded at 836 (offset 3 lines).
- Hunk #9 succeeded at 1103 (offset 3 lines).
- patching file ext/mysqlnd/mysqlnd_auth.h
- patching file ext/mysqlnd/mysqlnd_connection.c
- Hunk #1 succeeded at 671 (offset 5 lines).
- patching file ext/mysqlnd/mysqlnd_enum_n_def.h
- patching file ext/mysqlnd/mysqlnd_structs.h
- patching file ext/mysqlnd/mysqlnd_wireprotocol.c
- Hunk #1 succeeded at 2125 (offset 2 lines).
- Hunk #2 succeeded at 2272 (offset 2 lines).
- Hunk #3 succeeded at 2461 (offset 2 lines).
- Hunk #4 succeeded at 2690 (offset 2 lines).
- patching file ext/mysqlnd/mysqlnd_wireprotocol.h
- Patching MySQLnd to support SHA2 auth is done.
- Hunk #1 succeeded at 234 (offset -1 lines).
- configure: error: in `/usr/local/directadmin/custombuild/php-7.3.20':
- Done!
Checked to see if its already installed and it is:
Package gcc-8.3.1-5.el8.0.2.x86_64 is already installed.
Package gcc-c++-8.3.1-5.el8.0.2.x86_64 is already installed.
