[Clamav-announce] problem with daily.cvd 10938
Meesterlijk
Netherlands
Dear ClamAV users,
about 15 mins ago (1PM CET may 7th. 2010) we released daily.cvd 10938. This update apparently
caused a segmentation fault in all ClamAV versions older than 0.96
on 32 bit systems.
We just released daily.cvd 10939 which removes the faulty signature and
we have taken measures to ensure that this problem won't happen again.
We recommend using a monitor tool like clamdwatch or clamdmon to
automatically restart clamd whenever it dies.
If you are already using a similar solution, your clamd will be
restarted automatically as soon as freshclam downloads the daily.cvd
10939 update.
We apologise for the inconvenience.
Regards,
Luca Gibelli
ps2gamer
I confirm with freshclam this poses no concern. ;)
Received signal: wake up
ClamAV update process started at Fri May  7 13:23:11 2010
main.cvd is up to date (version: 52, sigs: 704727, f-level: 44, builder: sven)
Downloading daily-10939.cdiff [100%]
daily.cld updated (version: 10939, sigs: 63540, f-level: 51, builder: edwin)
bytecode.cld is up to date (version: 15, sigs: 2, f-level: 51, builder: nervous)
Database updated (768269 signatures) from db.fr.clamav.net (IP: 149.6.161.117)
Clamd successfully notified about the update.
ClamAV update process started at Fri May  7 14:23:11 2010
daily.cld is up to date (version: 10939, sigs: 63540, f-level: 51, builder: edwin)
ClamAV update process started at Fri May  7 15:23:11 2010
ClamAV update process started at Fri May  7 16:23:11 2010
Downloading daily-10940.cdiff [100%]
daily.cld updated (version: 10940, sigs: 63541, f-level: 51, builder: acab)
Database updated (768270 signatures) from db.fr.clamav.net (IP: 149.6.161.117)
ClamAV update process started at Fri May  7 17:23:11 2010
Trying host db.fr.clamav.net (149.6.161.117)...
Downloading daily-10941.cdiff [100%]
daily.cld updated (version: 10941, sigs: 63543, f-level: 51, builder: ccordes)
Database updated (768272 signatures) from db.fr.clamav.net (IP: 149.6.161.117)
ClamAV update process started at Fri May  7 18:23:11 2010
daily.cld is up to date (version: 10941, sigs: 63543, f-level: 51, builder: ccordes)
ClamAV update process started at Fri May  7 19:23:11 2010
nobaloney
California
add clamd and freshclam to Service Monitor and using update script, restart clamd and freshclam when down :)
Can you be more specific, to help admins who aren't sure how to do this?
