all DA tools are gone .I can see the taps on top but nothing else .
server was harden few days ago and da was working still good .
but after a reboot now all i can see is the top menu .
where example.com should be replaced by your hostname, and you should use either http or https depending on whether or not you use an SSL login.
Then change to a skin supplied by DirectAdmin.
If this fix works, then the problem is with your skin.
If it doesn't you may need someone to look into your server.
