cron problems
blueice
i have setup my first freebsd 5.2.1 box (until now i use 4.9 and it is very stalbe).
All things hope is ok but the cron for the users is not working.
One user have setup a cron but this is not runing. also in the cron log i not have see any info about this.
So i hope the users (at least the users) cron is not runing.
This is a common bug of 5.2.1 release of DA?
Christos
jmstacey
Colorado
Is DA putting the crons in the crontab.conf file succesfully?
/usr/local/directadmin/data/users/username/crontab.conf
blueice
yes the crons is here.
jmstacey
Colorado
I do not think its a bug since 5.x version is not beta anymore.
When a user creates a cronjob is a file placed with his username in /var/cron/tabs ?
Might want to check /var/log/directadmin logs and see if theres anything fishy in those.
blueice
yes the /var/cron/tabs/user is ok and also i not have see any error in directadmin logs.
Can someone of the directadmin team inform me all the places of files releated to user crons so i can checkit?
Christos
