Petertjuh360
- Nov 7, 2010
After rebuilding nginx_apache there is a space between http:// and IP:8080; at the parameter proxy_pass. When nginx restart it gives the following error:
After removing the space the problem is solved. This space is also present between "Listen" and the IP.
How can I solve this?
HTML:
Starting nginx: nginx: [emerg] invalid number of arguments in "proxy_pass" directive in /usr/local/directadmin/data/users/admin/nginx.conf:25
