tsiou
Hi, a small how to for dcc+razor+pyzor for spamassassin
cd /usr/ports/mail/razor-agents
make install
cd /usr/ports/mail/pyzor
make install
cd /usr/ports/mail/dcc-dccd
make install
vi /etc/rc.conf
dccifd_enable="YES"
dccifd_flags="-A -h /usr/local/dcc"
cd /etc/mail/spamassassin
mkdir .razor
mkdir .pyzor
pyzor --homedir /etc/mail/spamassassin/.pyzor discover
razor-admin -create -home /etc/mail/spamassassin/.razor/
razor-admin -discover -home /etc/mail/spamassassin/.razor/
razor-admin -register -home /etc/mail/spamassassin/.razor/
vi local.cf
use_dcc 1
dcc_timeout 10
dcc_home /usr/local/dcc
dcc_dccifd_path /usr/local/dcc/dccifd
use_razor2 1
razor_config /etc/mail/spamassassin/.razor/razor-agent.conf
use_pyzor 1
pyzor_options --homedir /etc/mail/spamassassin/.pyzor
add_header all Status _YESNO_, score=_SCORE_ required=_REQD_ tests=_TESTSSCORES(,)_ _DCCR_ _PYZOR_ _RBL_ autolearn=_AUTOLEARN_ version=_VERSION_
check that
loadplugin Mail::SpamAssassin:
lugin:
CC
lugin:
yzor
lugin::Razor2
are uncommented in the .pre files in /etc/mail/spamassassin/ directory
cd /usr/local/dcc
vi dcc_conf
check these values :
DCCD_ENABLE=on
DNSBL_ARGS="'-Bset:rej-msg=5.7.1 550 mail %s from %s rejected; see http://www.spamhaus.org/xbl/' -Bsbl-xbl.spamhaus.org,any"
DCCIFD_ENABLE=on
DCCM_ENABLE=off
vi /etc/crontab
25 1 * * * root /usr/local/dcc/libexec/cron-dccd 2>&1
/usr/local/etc/rc.d/dccifd start
ps auxw |grep dcc to see if deamon runs or we forgot something
/usr/local/etc/rc.d/sa-spamd restart
ps auxw |grep spam to see if deamon runs or we forgot something
tail -f /var/log/mailog to see the log of the spamd restart
log in your squirrel and check view full header of an email
copy all that you see
cd /tmp
vi test
paste and add at the bottom the word test or something
spamassassin -D <test 2>debug
vi debug
search for
[57380] dbg: dcc: dccifd is available: /usr/local/dcc/dccifd
[57380] dbg: info: entering helper-app run mode
[57380] dbg: dcc: dccifd got response: X-DCC-CTc-dcc2-Metrics: server 1031; Body=0
[57380] dbg: razor2: part=0 engine=4 contested=0 confidence=0
[57380] dbg: razor2: results: spam? 0
[57380] dbg: razor2: results: engine 8, highest cf score: 0
[57380] dbg: razor2: results: engine 4, highest cf score: 0
[57380] dbg: util: executable for pyzor was found at /usr/local/bin/pyzor
[57380] dbg: pyzor: pyzor is available: /usr/local/bin/pyzor
[57380] dbg: pyzor: opening pipe: /usr/local/bin/pyzor --homedir /etc/mail/spamassassin/.pyzor check < /tmp/$
to see if working...
I hope that i didnt forget anything, if have probles post a reply..
make install
make install
make install
vi /etc/rc.conf
dccifd_enable="YES"
mkdir .razor
mkdir .pyzor
vi local.cf
use_dcc 1
dcc_timeout 10
use_razor2 1
use_pyzor 1
check that
cd /usr/local/dcc
vi dcc_conf
DCCD_ENABLE=on
DCCIFD_ENABLE=on
DCCM_ENABLE=off
vi /etc/crontab
cd /tmp
vi test
vi debug
search for
