DirectAdmin Issues ( A few )
styles
I had the datacenter install DirectAdmin. It worked fine, I think, no errors. Now I needed Zend installed. So I used the auto installer and all the default settings for it. Then I needed LWP ( perl module ) for a script. I used CPAN to install it. As of those changes I am now getting a lot of errors from DirectAdmin.
PhpMyAdmin:
I get this error all the time:
Error
You probably tried to upload too large file. Please refer to documentation for ways to workaround this limit.
I also can not use the import function. It doesn't even load.
The other thing is I can't connect remotely to my MySql database. It saids connection time out or somthing. Any ideas?
Thank You.
