disk spaces problem
ali3781
I have a problem with configuration of DA on freebsd 7.0
when I add a domain,DA automatically use my first partition and it has only 500 MB,my question is how could I change this path to my other partition that it has about 400GB free space?
massive
you have to mount /home to your new partition.
There are a lot of guides about this. search google.
But i suggest if you are unexperienced user to hire someone to do it for you.
ali3781
thanks for your response.
I think I should change custom httpd configuration in DA panel,
could you tell me a simple solution to do this?
nobaloney
California
It may not be as simple as you'd like, but there's been a lot of discussion of this on these forums. This google search will help you find the information.
