DNS SOA problems
rat99
I have a main server with directadmin and I only have an ipv4 address and I bought another vps with an ipv4 address to use 2 nameservers.
I activated the multi server function on the main server and entered the data from the other directadmin.
But I have a little problem.
NSs have same SOA serialLooks like your nameservers do not agree on the SOA serial. Ths SOA records as reported by your nameservers:
xxx.xxx.xxx.239 -> 2020051503
x.xxx.xxx.253 -> 2020051604
This can cause some serious problems that is why you should fix this asap.x
server principal: https://prnt.sc/shxyj9
Zhenyapan
UA
just go to /var/named at xxx.xxx.xxx.239 -> and edit date in zonefile and restart named
also both zonefiles must be identical
