Hello
I need Nginx with Lua enable and I tried to build using Custombuild and I got the followings:
Here is my configure.nginx
Rich (BB code):
[root@my custombuild]# ./build nginx
Found /usr/local/directadmin/custombuild/nginx-1.19.6.tar.gz
Extracting /usr/local/directadmin/custombuild/nginx-1.19.6.tar.gz...
ModSecurity Connector v1.0.1 is now enabled in Nginx
Configuring nginx-1.19.6
./configure: error: invalid option " "
/usr/local/directadmin/custombuild/configure/nginx_reverse/configure.nginx: line 21: --with-ld-opt=-Wl,-rpath,/usr/local/luajit/lib: No such file or directory
#!/bin/sh
./configure --add-module=../modsecurity-nginx-v1.0.1 \
"--user=nginx" \
"--group=nginx" \
"--prefix=/usr" \
"--sbin-path=/usr/sbin" \
"--conf-path=/etc/nginx/nginx.conf" \
"--pid-path=/var/run/nginx.pid" \
"--http-log-path=/var/log/nginx/access_log" \
"--error-log-path=/var/log/nginx/error_log" \
"--without-mail_imap_module" \
"--without-mail_smtp_module" \
"--with-http_ssl_module" \
"--with-http_realip_module" \
"--with-http_stub_status_module" \
"--with-http_gzip_static_module" \
"--with-http_dav_module" \
"--with-http_v2_module" \
"--with-cc-opt='-D FD_SETSIZE=32768'" \
"--with-ld-opt=-Wl,-rpath,/usr/local/luajit/lib" \
--add-module=/opt/ngx_devel_kit-0.3.1 \
--add-module=/opt/lua-nginx-module-0.10.19
