I'm attempting to update exim from source following the instructions here:
http://help.directadmin.com/item.php?id=125
But the build fails, can someone help please? Here is what i get:
# make
>>> Creating links to source files...
Note (probably harmless): No library found for -lperl
>>> New Makefile installed
>>> Use "make makefile" if you need to force rebuilding of the makefile
make[1]: Entering directory `/home/chrisbolt/exim-4.71/build-Linux-i386'
/bin/sh ../scripts/Configure-os.h
/bin/sh ../scripts/Configure-os.c
gcc buildconfig.c
/bin/sh ../scripts/Configure-config.h "make"
make[2]: Entering directory `/home/chrisbolt/exim-4.71/build-Linux-i386'
make[2]: `buildconfig' is up to date.
make[2]: Leaving directory `/home/chrisbolt/exim-4.71/build-Linux-i386'
Building configuration file config.h
>>> config.h built
>>> exicyclog script built
>>> exinext script built
>>> exiwhat script built
>>> exigrep script built
>>> eximstats script built
>>> exipick script built
>>> exiqgrep script built
>>> exiqsumm script built
>>> transport-filter.pl script built
>>> convert4r3 script built
>>> convert4r4 script built
>>> exim_checkaccess script built
gcc exim_dbmbuild.c
In file included from exim.h:438,
from exim_dbmbuild.c:33:
dbstuff.h:103:16: error: db.h: No such file or directory
dbstuff.h:540: error: expected specifier-qualifier-list before ‘DB’
exim_dbmbuild.c: In function ‘main’:
exim_dbmbuild.c:150: error: ‘DB’ undeclared (first use in this function)
exim_dbmbuild.c:150: error: (Each undeclared identifier is reported only once
exim_dbmbuild.c:150: error: for each function it appears in.)
exim_dbmbuild.c:150: error: ‘d’ undeclared (first use in this function)
exim_dbmbuild.c:151: error: ‘DBT’ undeclared (first use in this function)
exim_dbmbuild.c:151: error: expected ‘;’ before ‘key’
exim_dbmbuild.c:213: error: ‘DB_HASH’ undeclared (first use in this function)
exim_dbmbuild.c:295: error: ‘content’ undeclared (first use in this function)
exim_dbmbuild.c:298: error: ‘key’ undeclared (first use in this function)
exim_dbmbuild.c:298: error: ‘R_NOOVERWRITE’ undeclared (first use in this function)
make[1]: *** [exim_dbmbuild.o] Error 1
make[1]: Leaving directory `/home/chrisbolt/exim-4.71/build-Linux-i386'
make: *** [all] Error 2
# make
gcc buildconfig.c
>>> config.h built
gcc exim_dbmbuild.c
